Thread Closed
[SOLVED] measure zero and differentiability
Share Thread
Nov24-07, 10:40 AM   #1
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I proved in the preceding exercise the following characterization of measure zero:
"A subset E of R is of measure zero if and only if it has the following property:
(***) There exists a sequence [tex]J_k=]a_k,b_k[[/tex] such that every x in E belongs to an infinity of J_k and
[tex]\sum_{k=1}^{+\infty}(b_k-a_k)<+\infty[/tex]"
Now the question is the following:
Let E be of null measure and {J_k} be as above. Let also [tex]f_E:\mathbb{R}\rightarrow\mathbb{R}[/tex] be the increasing function defined by
[tex]f_E(x) = \sum_{k=1}^{+\infty}\lambda(]-\infty,x]\cap J_k)[/tex]
Show f is not differentiable at any point of E.
2. Relevant equations
Differentiable iff the limit of the differential quotient exists and is bounded iff the left and right derivative are equal
3. The attempt at a solution
Let h>0 and x0 be in E. I can write the right derivative and use the additivity of measure to simplify to
[tex]D_rf_E(x_0)=\lim_{h\rightarrow 0}\frac{\sum_{k=1}^{+\infty}\lambda([x,x+h]\cap J_k)}{h}[/tex]
then what? What difference does it make than x is in E? I mean, how does the fact that is belongs to an infinity of J_k comes in?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Nov25-07, 09:50 PM   #2
Recognitions:
Is "x + h" in J_k for some h > 0?
Nov25-07, 10:09 PM   #3
Recognitions:
Well, each J_k is open and contains x, so for every k, there is an h, call it h_k such that x + h is in J_k, yes.
Nov27-07, 10:24 AM   #4
Recognitions:
Help!
Thread Closed
Similar discussions for: [SOLVED] measure zero and differentiability
Thread Forum Replies
[SOLVED] complete measure space Calculus & Beyond Homework 0
Differentiability on R Calculus & Beyond Homework 2
[SOLVED] The &quot;support&quot; of a measure Calculus & Beyond Homework 6
[SOLVED] Using the product measure Calculus & Beyond Homework 0
Differentiability Calculus & Beyond Homework 4
