Nailing Jello to a Tree: Uncovering Solutions
  • Thread starter Thread starter Math Is Hard
    Tree
The discussion revolves around the humorous and creative challenge of "nailing Jello to a tree." Participants explore various unconventional methods and strategies for achieving this seemingly impossible task, with a focus on imaginative solutions rather than practical applications. The conversation includes theoretical considerations, playful suggestions, and speculative ideas.
  • Some participants suggest freezing the Jello to make it easier to nail to the tree.
  • Others propose placing the Jello on a branch and nailing it down from there.
  • One idea involves nailing the entire box of Jello or the bag of powder to the tree without adding water.
  • A participant questions whether the Jello must be made according to standard directions, suggesting a gummy bear consistency instead.
  • Several creative solutions involve using unconventional methods, such as setting Jello in a shot-glass with a dart or constructing a large cube of Jello to support a tree.
  • Some participants mention the possibility of using antigravity or centrifugal force to assist in nailing the Jello.
  • There are suggestions to dehydrate the Jello or mold it around objects to enhance its stability for nailing.
  • One participant humorously suggests naming a cat "Jello" or writing "Jello" on paper to fulfill the challenge.
  • Another idea involves using a nail with a large head to support the Jello while nailing it to the tree.
  • Some participants reflect on the assumptions underlying the problem, particularly regarding the definition and preparation of Jello.
Participants express a variety of creative ideas and approaches, but there is no consensus on a single solution. The discussion remains open-ended with multiple competing views and playful suggestions.
The discussion is limited by the playful nature of the problem, which allows for a wide range of interpretations regarding the preparation and properties of Jello. Participants do not agree on specific constraints or definitions, leading to diverse and imaginative solutions.
Math Is Hard
Staff Emeritus
It's been said that this is impossible, but there must be a handful of legitimate solutions. I'm writing an essay about solving a challenging problem and I am thinking about using this as a lead in, offering a few strategies for a solution.
Any ideas? Freezing the Jello seems like it might work if one nailed it carefully.
hmmm..Maybe sitting the Jello cube on top of a branch and then nailing it down is another possibility.
Nail the bag of powder to the tree [don't add water]
Nail the entire box to the tree
Ahhh.. clever!
Does the jello have to be made according to directions?
You make jello into gummy bear consistency which could be nailed to a tree.
Cut down the tree, nail the Jello to the tree and drop the tree into a bottomless pit.
Place a wedge into the tree, nail small piece of Jello directly on top of the wedge.
Add lots and lots of gelatin to the Jello, and then nail it.
I'm assuming it's a free-for-all on how the jello is made or whether it's made at all, so these are good suggestions.
Yep, sometimes it's best to think INSIDE the box. :biggrin:
You could also put it in a Ziploc bag and nail the bag to the tree.
Or, you could make Jello shots, and invite an appropriate male/female mix of guests to the party...somebody might get...:rolleyes: Nevermind, that's not rated PG. :blushing:
That works, too!
I was also thinking about what DDMC wrote. I wonder if there is some antigravity or centrifugal force related solution?
:blushing::biggrin:
That might be a bit racy for my class essay.
Stretching the usage of nail just a little...set the jello in a shot-glass with a dart inverted into it so that the jello sets around the fletching (the fins).
Or, for a simpler solution, make a standard 100ft by 100ft by 100ft cube of jello, cut down a smallish tree and nail it to the top of the cube. Then put yourself in the reference frame of the tree.
Oh, very cool!
Just put the jello on the tree. Jello is nails.
Math Is Hard said:
That works, too!
Use an extremely dense nail? The local gravity will hold the jello in place.
You could also name the cat Jello...
or just write "Jello" on a piece of paper and nail it up.
Speaking of Jello, I had to mention this
The Extended Analog Computer (EAC) is a device which
computes using semi-conductive material, voltage gradients,
and logic arrays. The computational medium can be any semiconductive
material, such as black conductive foam, Jello
brand gelatin, or silicon. Voltage gradients are induced on the
conductive medium through the use of a series of sources and
sinks. Sources transmit electrical current to the medium by
producing an excess of electrons. These electrons, once on
the medium, tend to travel towards a sink. A sink provides a
path of least resistance for the electrons to exit the board. This
is either a ground or a negative voltage source.
As electrons flow across the medium from sources to sinks,
a voltage gradient is produced. This gradient can then be
sampled across the medium to produce a graph of the electrical
flows occurring on the conductive medium. Logic arrays are
used in order to modify the electrical currents being output to
the medium.
http://www.cs.indiana.edu/cgi-pub/cshue/research/techreport624-06.pdf
so you may be able to calculate a solution using a jello analog computer.
Make up the jelly and set it in a small cylindrical container with the nail already in it so that it clings to the nail, then hit it into a tree.
I reckon you could actually nail jelly to a tree, with no modifications to the nail or jelly. You'd just have to be a bit careful.
Math Is Hard said:
That works, too!
Construct an enormous centrifuge and place a tree in it. Then get in with your Jello, hammer and nails and start the centrifuge. Then when you get going fast enough carefully nail the Jello to the tree.
Or hammer twenty nails in a circle leaving a hole in the middle where you place your Jello.
Make a small container of jello, and when it sets up, punch a small hole through the center of the jello and put the jello in the freezer. When it's frozen, you can nail it to a tree, and it ought to stay put until it thaws, which could be a long time coming in my climate.
Put the jello in a shallow tray and dehydrate it to a leathery texture, then nail it.
I liked gokul's idea of molding the jellow on the dart feathers, if you made it dense or dried it enough, it wouldn't slip off.
Thanks for the ideas, everyone. I love the creative minds here.
It also depends on how much Jello you intend to nail to the tree. Just passing the nail through the jello should pick up enough on the nail to embed within the tree on the nail, even if you'd need a microscope to find it.
We'll call this the "CSI solution".
:smile: Indeed, as I suggested it, one of those CSI scenes went through my mind. We'd hear the "splat" sound as the nail goes through the jello, then a *crack* as the nail passes through the wood, and we'd watch the nail with wiggly globs on it come at us, as if we were inside the tree. :biggrin:
So, it seems to me, that the trick to finding new solutions is to identify the assumptions that appear to come with the initial problem. In this case it mostly concentrates on what one can do (or not do) to Jello recipe-wise and still have it be defined as Jello.
Put a cube of jello on a narrow board and hold it against the tree. Use a nail with a large head and carefully push it through the jello until it contacts the tree. Now carefully drive the nail at at an upward angle so that the jello will be partially supported on the nail head. Stop hammering before you blast all hell out of it.:smile:
Nail guns are not recommended.
http://www.mazelumber.com/catalog/catalog.pl?page=PAGE27&group=PLH
Screwing jello to a tree with a large washer on the screw is even easier. You can even turn the screw with a cordless drill.
You can also freeze the jello then drill a small hole through it. Put the nail through the hole and hammer as needed.
This message will self destruct in 7 seconds.
For an extra point, who can locate a PF post showing jello nailed to a tree?
Hint: Good thing Smurf and LYN aren't around very much.
http://scribalterror.blogs.com/scribal_terror/images/knoxjello.jpg
http://www.nitefallz.net/images/1/Image03.jpg
do I get at least half a point for jello nailed to a piece of plywood pic link?
(didn't feel like posting pic by direct pic)
  • · Replies 46 ·
  • · Replies 21 ·
  • · Replies 39 ·
10K
