Definitions of few physics terms
This discussion clarifies the definitions of specific gravity and specific weight in physics. Specific gravity (SG) is defined as the ratio of a substance's density (rho) to the density of water at 4 °C, expressed as SG = rho/rho(H2O). It is established that specific gravity is consistently calculated using the density of water at 4 °C, which is 1000 kg/m³. The discussion also highlights that specific weight is calculated using the formula gamma = rho * g, where g represents the acceleration due to gravity. The practical benefit of these definitions lies in their ability to simplify the comparison of densities without the need for complex volume measurements.
  • Understanding of density and its units (kg/m³)
  • Familiarity with the concept of specific gravity
  • Basic knowledge of gravitational acceleration (g)
  • Awareness of temperature's effect on water density
  • Research the impact of temperature on the density of various substances
  • Learn about the applications of specific gravity in material science
  • Explore the differences between specific weight and density in engineering contexts
  • Investigate methods for measuring the density of irregularly shaped objects
Students, educators, and professionals in physics, engineering, and material science who seek to deepen their understanding of density-related concepts and their practical applications.
Micko
Hello people,
Please, can you help me understand meaning of few definitions like:
First, there is so called specific gravity, defined as relative quantity:
SG = rho/rho(H2O) at temperature of 4 °C. Since water's density at 4 °C is 1000 kg/m3 = 1 g/cm3, it seems that specific gravity is always rho/1000 if rho is in kg/m3. What I don't know is if this definition is applicable to any substance, so for example, if we speak about SG of iron, it is rho(iron)/1000 if calculated at 4°C. Is this always defined according to ref. tmperature of 4°C or not?
What confuses me is that I found in one table that SG of water at 0°C is 1.0. I believe this is mistake since water's density at 4°C is 1000 kg/m3 and not at 0°C. Is this correct?
Also, specific weight is defined as gamma = rho * g? What is practical benefit of using these quantities? Isn't plain ordinary density sufficient?
The specific gravity is the relative density of a substance wrt water at 4 degrees C as you have stated. This means the denominator will always be 1000. I'm not sure if the temperature really matters since relative density is just used to compare unknown substances (i.e. compound substances such as rocks) with something that is we defined. Someone can correct me if I'm wrong. The point of the comparison is that it gives one an easy way of finding out the density of something without having to do tricky things like measure its volume.
  • · Replies 26 ·
10K
