Optimization problem with graph
  • Thread starter Thread starter 2000xjclassic
    Graph Optimization
The discussion centers on optimizing fuel efficiency using a graph that plots gallons of fuel per hour against miles per hour. Participants confirm that the optimal speed for maximizing fuel efficiency corresponds to the points where the first derivative of the graph equals zero. This indicates that the original graph has a horizontal tangent at these points, confirming that the optimal speed and the speed for maximum fuel efficiency are indeed the same.
  • Understanding of graphing functions and their derivatives
  • Knowledge of optimization techniques using calculus
  • Familiarity with the concept of horizontal tangents in graphs
  • Basic skills in interpreting graphical data
  • Study the application of the first derivative test in optimization problems
  • Learn how to identify critical points on a graph
  • Explore the relationship between fuel efficiency and speed in automotive engineering
  • Review calculus concepts related to derivatives and tangents
Students in calculus, engineers focusing on fuel efficiency, and anyone interested in the mathematical principles behind optimizing performance based on graphical data.
2000xjclassic
We are given a graph of gallons of fuel per hour versus miles per hour and asked what speed should be used to maximize fuel efficiency and also what is the optimal speed(are these two the same thing).
I understand optimization using the first derivative when given an equation, I am having a problem with figuring out what to do with only a graph
I have graphed the first derivative. should I use the zero points from the first derivative graph to optimize the fuel efficiency?
Thanks in advance.
Chris
"Optimal" simply means "best". IF "optimal" here means "best fuel efficiency", then they are the same.
Thanks in advance.
Chris
Yes, the max or min points will be where the first derivative is 0. I don't know that you really needed to graph the entire derivative. The derivative will be 0 where the original graph has a horizontal tangent.
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 21 ·
