Power of Elevator Motor at Cruise Speed
  • Thread starter Thread starter mkwok
    Elevator Power
The discussion revolves around calculating the average power of an elevator motor during its acceleration phase and comparing it to the power at cruising speed. The subject area includes concepts from dynamics and power calculations in physics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the calculation of average power using different approaches, including the use of average velocity and net force. There are questions about the correct application of formulas and the interpretation of forces acting on the elevator.
Participants are actively discussing their attempts to solve the problem, with some expressing confusion about previous responses and calculations. There is a recognition of the need to clarify the forces involved and how they relate to the power calculations. Some guidance has been offered regarding the correct force to use in the calculations.
There is mention of the original poster's difficulty in finding previous replies, which may affect their understanding. Additionally, there are indications of potential misunderstandings regarding the forces acting on the elevator and how they influence the power calculations.
mkwok
First of all, I know I've posted this already, but I didn't really understand the reply. I tried going back to the thread, but I can't find it anymore.
A 750 kg elevator starts from rest. It moves upward for 3.00 s with constant acceleration until it reaches its cruising speed, 1.75 m/s.
(a) What is the average power of the elevator motor during this period?
(b) How does this power compare with the motor power when the elevator moves at its cruising speed?
F=ma
P=FV
(a), since it was asking for the "average" power, so I thought I'd take the average velocity for my equation
so Force = ma = 750*(1.75/3)
and P= 750*(1.75/3)*(1.75/2) = 382.81
However, that is the wrong answer
so I tried it again.. may be I used the wrong numbers? This time I did the following:
Force = ma = 750*(9.8)
and P= 750*(9.8)*(1.75/2) = 6431.25
However, this is still wrong
what am I missing?
(b) I think I am stuck on this part because I don't fully understand part a... but I was actually thinking that may be the power of done by the elevator at cruising speed would just be
P=Fv=mgv = 750*9.8*1.75 = 12862.5
this is definitely wrong because I typed it into my online hw, and it told me its wrong
ok wait...The resultant force acting on the elevator is upwards...the only forces acting to provide this are the upward force of the elevator,[itex]F_E[/tex] and the downward force of the elevator(it's weight,[itex]W[/itex]). So that the resultant force,[itex]F_R[/itex] moves upward for 3.00 s with constant acceleration until it reaches its cruising speed, 1.75ms[itex]^{-1}[/itex][/itex]
1.75/2 because it started at rest where Vi=0, and vf=1.75
so the average would be 1.75/2
F=ma
P=FV
what am I missing?
It's unfortunate that you couldn't find your first post buried on page 3 a moment ago, because you practically had the correct answer by correctly calculating the work done by the motor, then you forgot to divide the work by the time (3 seconds) to get the average power delivered by the motor. Anyway, now you have chosen wisely to determine the average power using the motor force times the average velocity, however, you are now incorrectly using the net force acting on the elevator, when instead, you should be using the force provided by the motor, [tex]F_m[/tex], where [tex]F_{net} = F_m - mg[/tex]. For part b, your answer appears correct, because at cruise speed, the motor force must equal the weight (per Newton 1), so I don't know why the computer doesn't like your answer.
  • · Replies 31 ·
  • · Replies 23 ·
