What angle do I use to find the perpendicular force in torque calculations?
  • Context: High School
  • Thread starter Thread starter kevinr
    Confused Torque
The discussion revolves around understanding how to determine the correct angle to use in torque calculations, specifically in the context of the formula T = r x F. Participants explore the relationship between the angle, the position vector, and the force vector, and how these affect the calculation of torque.
  • One participant expresses confusion about identifying the correct angle for torque calculations, questioning whether to use sine or cosine in the equation T = r x Fsin(theta).
  • Another participant clarifies that theta should be the angle between the position vector r and the force vector F, suggesting that trigonometric identities can sometimes provide equivalent angles.
  • A participant raises the issue of ambiguity in determining theta, noting that it can be defined in clockwise or counterclockwise directions, leading to different angle measurements.
  • Another participant advises to always take the shortest angle between r and F to determine the correct direction for torque, while also noting that using a larger angle will yield a negative sine value, indicating a need to reverse the initial answer.
Participants do not reach a consensus on which angle to use, as there are competing views regarding the definition of theta and the implications of choosing different angles in torque calculations.
The discussion highlights the potential for confusion regarding angle definitions in torque calculations, particularly the distinction between clockwise and counterclockwise angles, and the implications for the sine function used in the torque formula.
kevinr
Hello.
I just learned torque and i am really confused about one thing.
T = r x F.
Now in the above Torque, we need to find a perpendicular force part which contributes to the torque compared to the r.
Hence: T = r X Fsin(theta).
But i get confused in the following example:
http://img187.imageshack.us/my.php?image=physicslu1.png
Basically i am so confused of how to find r x F (i know you try to find perpendicular but it doesn't make sense because i saw some problems in my book use even cosine).
Could anyone please clarify which angle you use (outside / inside) compared to r and whether you need cosine or sin.
(In the diagram, if the force was instead pushing up on r, would the same angle be used compared to it pushing down on r? )
You can take clockwise angle or counterclockwise angle. So I am lost.
THanks for your time!
When computing [itex]rF\sin\theta[/itex], [itex]\theta[/itex] is the angle between [itex]\vec{r}[/itex] (which is a position vector from the pivot to the point of application of the force) and [itex]\vec{F}[/itex]. With a bit of trig, you can often use another angle to get an equivalent answer (for example, [itex]\sin\theta = \sin(180 - \theta)[/itex] or [itex]\sin\theta = \cos(90 - \theta)[/itex]).
True but what i don't understand is which [itex]\theta[/itex] to take: [itex]\theta[/itex] can be clockwise / counterclockwise between r and F.
(Say you start at force and go to r which gives you the angle between them. If you go clockwise you get a different angle than counter clockwise).
Always take the shortest path (the smallest angle) between r and F. That will give you the correct direction for the torque. But it doesn't really matter, since the [itex]\sin\theta[/itex] will correct you. If you choose the larger angle, [itex]\sin\theta[/itex] will be negative, which tells you to reverse your initial answer.
Ah thank you!
  • · Replies 37 ·
  • · Replies 32 ·
  • · Replies 37 ·
