What is the connectedness problem from Conway's Complex Analysis?
  • Context: Graduate
  • Thread starter Thread starter rudinreader
The discussion revolves around the connectedness problem as presented in Conway's Complex Analysis, specifically regarding the implications of connectedness in closed sets and the existence of sequences of points within those sets. Participants explore definitions, examples, and proofs related to connectedness and path-connectedness in topology.
  • One participant questions the implications of a closed and connected set, seeking clarification on whether the property of taking arbitrarily small steps between points A and B is a general concept.
  • Another participant suggests that the ability to connect points A and B through small steps could serve as a definition of connectedness, indicating a continuous path exists within the set.
  • Some participants argue that the property of having arbitrarily close points does not necessarily imply connectedness, providing examples of sets that are closed but not connected.
  • There is a distinction made between connectedness and path-connectedness, with some participants noting that certain sets can be connected without being path-connected.
  • A proof is proposed by one participant that aims to show the existence of a sequence of points connecting A and B in a connected metric space, although others question the relevance of the closed property in this context.
  • Another participant expresses uncertainty about the proof's validity, emphasizing that the focus should be on the existence of a sequence between A and B rather than the closed nature of the set.
  • Discussion includes a puzzle involving the construction of two disjoint connected sets within a closed square, highlighting the complexity of connectedness and path-connectedness.
  • Participants correct each other on the nature of closed connected sets, with one asserting that not all closed connected sets are path-connected, referencing the "topologist's sine curve" as an example.
Participants express differing views on the relationship between connectedness and path-connectedness, with no consensus reached on whether the properties discussed imply one another. The discussion remains unresolved regarding the implications of closedness in the context of connectedness.
Participants note the existence of pathological cases in topology where connected sets may not be path-connected, and the discussion highlights the complexities and nuances in definitions and properties of connectedness.
rudinreader
From Conway's Complex Analysis, page 17, 2.2.5:
Suppose [tex]F \subseteq X[/tex] is closed and connected. If a,b are in F and e > 0, then there exists [tex]a = z_0,z_1,...,z_n = b[/tex] such that [tex]d(z_{k-1},z_k) < e[/tex] for k in {1,...,n}.
I don't see the answer to this off the top of my head.. anyone else see it? Is this a special case of a more general idea?
It means that in a connected, closed region, you can get from point A to point B by taking arbitrarily small steps, within the region. In fact, it seems like you could even take this as the definition of "connected", as far as I can tell. It seems to be saying, "There is a continuous path in F from A to B".
But satisfying the property above doesn't imply connectedness. Here are some examples(and the last one is closed):
Q, the rationals
[tex][0,1) \cup (1,2][/tex]
[tex]\{(x,\frac{1}{|x|} ): x < 0\} \cup \{(x,\frac{1}{|x|} ): x > 0 \}[/tex]
True...the sequence being described isn't actually continuous. The connectedness property does imply, however, the existence of a sequence of arbitrarily-close points which begins at A and ends at B.
I thought this was interesting and decided to read a bit about connectedness, as topology isn't really my specialty. Apparently there is a distinction between connectedness and path-connectedness. Path-connectedness is what I described, which is not quite what your text describes, so I was wrong. There also exist, it seems, certain pathological cases which are connected but not path-connected.
The "sequence-connected" version you have should be true of all connected spaces, though. However, the converse is not true. I'm not sure what you're asking...were you trying to prove it?
OK I got it.
Ok here's a proof. It's not as hard as I thought. Fix e > 0, and a,b in X.
Let [tex]A = \{z \in X: there \ exists \ a = z_0, ..., z_n = z \ in \ X \ such \ that \ d(z_{k-1},z_k) < e \}[/tex].
We have a in A, so A is not empty. To prove b in A, it suffices to prove A is open and closed in X, hence A = X.
To do that, you suppose [tex]z \in A[/tex]. Then choose a sequence [tex]a = z_0,..., z_n = z[/tex] such that [tex]d(z_{k-1},z_k) < e[/tex]. Then for any y in [tex]B(e,z)[/tex], just set y = [tex]z_{n+1}[/tex]. That shows y in A, hence A is open in X.
To show A is closed, you choose a point z in X\A, and using a similar argument (of appending to the end a sequence), show that there is no sequence connecting a to any point of a neighborhood of z.
Yes, I was trying to prove it.. and in the proof I just threw away the F, and considered a connected metric space X. So that's more general. A connected closed subset F is of course a connected metric space.
I'm not sure what your proof is proving. We already know that a and b are in F; we're trying to prove that a sequence exists between a and b whose elements z_i are arbitrarily close together.
It seems to me that this should follow from the fact that F is connected. I don't see how F being closed figures into it at all...(and in fact, as your earlier examples showed, F doesn't even have to be connected for the sequence to exist).
What I did was fix e > 0, and defined a set A to be the z in X that has such an "e-path" to a. I showed b was in A (because A=X). Yes, I threw out the closed part. In the proof, I don't mention F, I just look at a connected metric space X.
Any path-connected set is connected, any open connected set is path connected, any closed connected set is path connected.
Here's a puzzle I concocted several years ago: Find 2 sets P and Q, both contained in the closed square in R2 with vertices at (1,1), (-1,1), (-1,-1), and (1, -1) such that:
a) P contains (1,1) and (-1,-1) while Q contains (-1, 1) and (1, -1)
b) P and Q are both connected sets
c) P and Q are disjoint.
This can be done by defining P and Q as the graphs of two functions such that the graphs are connected but NOT path connected.
I assume that's a typo. Because the "closed topologists sine curve" is a closed connected set that is not path connected.
Your puzzle is interesting, but I don't see the trick in constructing the said P and Q. Any more hints without giving it away?
I wish it were a typo! I just plain mis-spoke. Thanks for the correction.
Make the middle part of each path a variation on y= sin(1/x) (is that the "topologists sine curve" you were referring to?). multiply by, say, 0.95 to keep it inside the square and add or subtract 0.03 to get them "miss" each other.
  • · Replies 24 ·
