How Long Does It Take a Package to Travel Through a Planet in a Gravity Tunnel?
  • Thread starter Thread starter chaotixmonjuish
    Gravitation
The discussion revolves around a theoretical scenario involving a package traveling through a gravity tunnel bored through a planet, as well as a problem involving gravitational forces between multiple spheres. The subject area includes gravitational physics and concepts related to motion through gravitational fields.
  • Participants discuss the gravitational force acting on the package and its implications for motion through the tunnel. There are questions about how to apply gravitational calculations to determine travel time. In the second problem, participants explore the net gravitational force acting on a central sphere and suggest methods for breaking down the forces into components.
Some participants have offered insights into the nature of gravitational forces within the planet and suggested methods for analyzing the forces acting on the spheres. There appears to be a divergence in interpretations regarding the motion of the package and the behavior of the gravitational forces, with no explicit consensus reached.
Participants are working under the assumption that the planet is a homogeneous sphere and are considering the implications of simple harmonic motion (SHM) in the context of the package's travel through the tunnel. There may be constraints related to the assumptions made about the gravitational field and the setup of the problems.
chaotixmonjuish
A tunnel is bored through the center of a planet, as shown in the Figure (this drawing is NOT to scale and the size of the tunnel is extremely exaggerated). Assume that the planet is a homogenous sphere with a total mass M = 3.6 × 1024 kg and a radius R = 7300 km. A package of mass m = 7.8 kg is dropped into the tunnel. If the tunnel is used to deliver mail from one side of the planet to the other, how long would it take for a letter to travel through the planet?
I got the magnitude of gravitation as 23.1 Newtons, but I'm not sure what to do with it and how to use it to figured out how long it would take to travel through the planet.
My next question:
Four spheres form the corners of a square whose sides are 10 cm long. The masses of the spheres are m1 = 950 kg, m2 = 200 kg, m3 = 600 kg, and m4 = 950 kg. What is the magnitude of the net gravitational force from them on a central sphere with mass m5 = 950 kg?
img:http://i242.photobucket.com/albums/ff106/jtdla/prob10.gif
I tried using the pytagorean theorem to get a hypotenouse (5^2+5^2=radical(50)) and putting that in the denomentator of the various masses times 950. After summing them up I still didn't get the answer. Any ideas?
Q1.
Find the grav force at a dist r from the centre of the earth, where r<R of earth. It's not a constant force, as you have written. But you'll be surprised to see that it's another kind of force very common in Physics.
Q2: Start by turning the square into a diamond by rotating it so that the middle ball lies at the origin and te others lay on axis in an xy plane. Separate the forces into components and allow them to cancel where able. Then subtract the forces from each other until you are left with net gravitation.
Q1.
I think the mail will never reach the other side of the planet.
It executes SHM
the object moves with SHM, but energy is conserved. The object will reach the other side of the planet at the heigt it was dropped from at the exact moment its speed reaches zero. for more information look up Hooke's theory of gravity trains.
  • · Replies 20 ·
17K
9K
