| Thread Closed |
statics- beams internal effects...i dont get it |
Share Thread |
| Nov28-07, 10:07 PM | #1 |
| Nov28-07, 10:43 PM | #2 |
Between 0 and 4, the loading is linearly varying; betweem 4 and 8, it is uniform; no distributed load the rest of the way. The sections are chosen to reflect these different loading variations. Between 0 and 4, the load varies fron 0 to 100lb/ft over the 4 foot length; thus, by taking a free body diagram of this section that includes the left support and cuts through the beam at a distance x from the left, the total loading is the area of the triangular distribution which has a length x, and a height of 100x/4 (from the basic geometry of slopes), thus the area is 1/2 the base times height = 12.5x^2, that's the total of the distributed load at that point. Now when you look at the section between 4 and 8, your free body diagram includes the known reaction at the left support, and you determine shears and moments in accordance with the translational (sum of fy =0) and rotational (sum of moments = 0) equilibrium equations.
| Nov28-07, 11:29 PM | #3 |
thanx, i understand that part, its just the whole x thing that confuses me. i know im not explaining myself very well, sorry. my dad just explained to me where 100x/4 and 12.5x^2 come from so i got that part now. you know what, screw it. i think i know it enough to be able to solve the problem. i think i just need help with the final part of calculating the max moment and its location x from the left.
my dad pointed out that if you take the derivative of the moment from the 4<x<8 section and set it equal to 0, you get the answer for the distance x from the left....that being 4.47ft. and if you take 4.47ft and plug it back into the original moment equation, thatll give you the maximum moment. what i dont get it how are you supposed to know to use the second section's moment? intuitively it makes sense, but what about on a more difficult problem where its not quite so obvious? how do you choose which moment to use? or is there some way to use them all to get the answer? |
| Nov29-07, 11:06 AM | #4 |
| Nov29-07, 03:25 PM | #5 |
ok thanx. well i def failed the test today. i dont think i did too bad on the beam problem, but i did HORRIBLE on the centroid problem :( i think my prof picked the hardest possible centroid problem and then made it even harder.
| Nov29-07, 03:45 PM | #6 |
| Dec3-07, 08:18 PM | #7 |
the one on the test was a little easier, but i know i screwed up at the points where the sections end. i am still confused about that and i think i ended up leaving an entire force out, lol. i was also rushed because i wasted too much time on the centroid problem. but i will see tomorrow what i got. just gotta worry about the final now :(
| Dec3-07, 08:19 PM | #8 |
btw, thank you for the help :)
| Thread Closed |
Similar discussions for: statics- beams internal effects...i dont get it
| Laser Beams | Biology, Chemistry & Other Homework | 4 | ||
| Bending of J Beams | Mechanical Engineering | 6 | ||
| Beams of light and wave effects..... | General Physics | 2 | ||
| Please Help! Internal Forces in Statics | Introductory Physics Homework | 2 | ||
| Two Beams | Introductory Physics Homework | 1 | ||
