Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Earth
Reply
image log - rock - scissors Share It Thread Tools Search this Thread image
Old Dec4-07, 02:19 PM                  #1
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
PF Contributor PF Contributor
Roshambo is the name for a popular two-person hand game. It may also be referred to as Paper, Rock, Scissors. Rock blunts scissors, scissors cut paper, paper folds around rock. Nature plays it too. But instead of paper it uses logs:
Log folds around rock:
http://gallery.myff.org/gallery/177736/log3-tn.JPG
Picture courtesy of a geology studying friend
It's mystery solving time again. What the *bleeb* happened here?
Old Dec4-07, 02:24 PM                  #2
matthyaouw
matthyaouw's Avatar
matthyaouw is Offline:
Recognitions:
I'd say landslide, debris flow or something of the sort. Hard to say without seeing it first hand.
Old Dec4-07, 02:26 PM                  #3
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
The soil is glacial till. Answers a question but that should also raise more questions.
Old Dec4-07, 02:39 PM                  #4
matthyaouw
matthyaouw's Avatar
Recognitions:
Where is it? I've seen wood in not too bad shape in late tertiary deposits. Perhaps the glacier stirred up some earlier sediment. Any idea on the type of tree?
Old Dec4-07, 02:50 PM       Last edited by Andre; Dec4-07 at 03:06 PM..            #5
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
I'll ask about the species. Since the log is still in situ, stirring up earlier sediment is highly unlikely. That would have disrupted the scenery. But would the stirring up have caused the folding? No, because you can't bent old dead wood like like that. It would shatter. This log was folded when the wood was still alive. Now, what kind of problems would that give?
Incidentely the age of the log is beyond the carbon dating limit of about 55,000 years and the till is illinoian. >130.000 years
edit/ update: the species is spruce (Picea). The location is given in the opening post, Ohio, is in the bank of a creek, which may have erode away the till to expose the log again.
Old Dec4-07, 03:14 PM       Last edited by matthyaouw; Dec4-07 at 03:29 PM..            #6
matthyaouw
matthyaouw's Avatar
Recognitions:
How can you tell it's in situ?
I've never worked very much so I'll take your word that it isn't ordinarily possible, even if waterlogged. Things behave pretty strangely under pressure though. Ever seen chalk rafting in till? That picture isn't a great example, but you can get folds of chalk and till reminiscent of the rock folds you see in the alps, all from the weight and movement of an ice sheet. I wouldn't be surprised if wood would do some strange things in that circumstance.
edit-some good pictures and info to be found here:
http://www.geog.soton.ac.uk/users/ha...rs/roberts.pdf
Old Dec4-07, 03:29 PM                  #7
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
Well, I guess that folding rocks or wood are two different things. But it would surely be worth while to find out if fossil water logged wood could still bend that way. nevertheless, it's proposed by scholars of the Cincinnaty Uni that the wood was bend alive. If that is correct then we would have a life spruce forest overrun by an advancing ice mass. Possible? probable?
Old Dec4-07, 03:52 PM                  #8
matthyaouw
matthyaouw's Avatar
Recognitions:
Got a link to any more info?
Old Dec4-07, 04:39 PM                  #9
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
No it's ungoing investigation. No publications around. But the nagging question for me indeed is the feasibility of life forest overrun by glaciers.
For instance the Picea treeline runs roughly from North Alaska to the southerly shore of the Hudson Bay around 59N lattitude, the closest permanent snow/ice on Baffin Island is around 70N, that's more than 700 miles that a hypothetical ice sheet would have to advance before reaching the Picea forest. How fast would that have to happen for the the Piceas to be still alive or fresh; As the treeline also moves south at comparable rates with the ice.
Old Dec4-07, 05:09 PM                  #10
matthyaouw
matthyaouw's Avatar
Recognitions:
Its a bit of a puzzle it seems. Is this tree one of many then? If so, how far do they extend? Is there any evidence of soil horizons? Trees don't just grow on 'fresh' till. I'd expect a podsol for coniferous forest.
Old Dec5-07, 04:11 AM                  #11
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
Yes several other similar logs have been found in the same area. Not sure about the soil conditions. Additinal to the physics of the wood bending, we also have to consider that this may have had to happen under freezing conditions. Frozen wood is likely rather britle. So what is wrong with the story?
Old Dec5-07, 07:51 AM                  #12
J77
J77 is Offline:
Couldn't the wood have been bent when it was wet...?
Old Dec5-07, 07:59 AM                  #13
matthyaouw
matthyaouw's Avatar
Recognitions:
There is often water at the base of an ice sheet due to geothermal heat & pressure melting. Till can often be saturated.
I'm not even convinced we have enough of a story to work with yet.
Old Dec5-07, 10:49 AM                  #14
jim mcnamara
jim mcnamara is Offline:
Recognitions:
Here is a paper on Picea bending, fresh (green) wood:
http://heronpublishing.com/tree/freetext/27-1229.pdf
Also note in the picture that there are splits in the wood. Split wood is far easier to bend, and is a standard technique (lamination or lathing) employed to bend green wood.
IMO what you see is the result of green wood under constant stress for a long period. There is no way to rule out krummholz or avalanche starting effects as far as I can see.
In other words you cannot say definitely how much bending happened before or after burial of the wood. However, it is more difficult to bend any further already stressed and bent wood because of reaction wood. That is, to bend it without breaking it.
Taunton Press has a book on Wood Bending, which includes bending green wood.
Small diameter (~3cm and smaller) stems can be made into horseshoe shapes. Green Salix is a piece of cake to bend....
Example picture:
http://www.aroundthebendwillowfurnit...m/seating.html
Old Dec5-07, 01:58 PM       Last edited by Andre; Dec5-07 at 02:08 PM..            #15
Andre
Andre's Avatar
Andre is Offline:
Recognitions:
Thanks Jim The essential question here are how long (order of magnitude 1-10-100-1000 years) could the wood have been death before it was bend. That would say something about the time between the treeline passing south and the glacial over run. If trees are left dead 100 years the wood would be rather stiff and more brittle. It would not bend easily without breaking.
I have questioned the current condition of the wood. It's damp (the creek) and firm but seemed in good condition. The appearance was it to be not that old at all, which seems confirmed by the picture. This hints on perfect conservation deep in the till before the creek washed the soil away.
The bends are definitely flexible and over there they don't doubt that it was bend when *alive*, J77, old Picea wood is not that flexible at all even when soaking wet.
If the bending took place under great pressure, Matt, like your chalk example, then you would expect the wood cellular structure to be destroyed, that seems not to be the case.
So the scenario seems that there was a normal spruce parcel that got overrun by a glacier when the wood was still fresh. I would not have a problem with that if we were talking mountain glaciers, advancing some meter per day to a week, which would not melt in the valley anymore due to the extreme ice age cold.
But there are no mountains in Ohio and in the horizontal plane there are many hundreds of miles of treeless tundra between the northermmost piceas and the souternmost permanent snow areas.
So that's why I still think something doesn't add up and this publication doesn't make that better:
Heuser et al 2002 Late Wisconsin periglacial environments of the southern margin of the Laurentide Ice Sheet reconstructed from pollen analyses, JOURNAL OF QUATERNARY SCIENCE (2002) 17(8) 773–780
Assuming that the pollen spectra represent regional vegetation of the southern margin of the Miami lobe of the Laurentide Ice Sheet, we conclude the following:
1 ...;
2 at the same time, Picea was present on the southern margin of the Miami lobe of the Laurentide Ice Sheet, even though pollen percentage values do not reach levels that indicate the local presence of spruce before ca. 17 500 14C yr BP; (Andre: ~20600 calendar years ago)
3 ...
4 climatic amelioration inferred from the development of spruce parkland with oak ca. 15 000(A: ~18.500 Calendar years ago) was terminated by the ca. 14 500 14C yr BP ice advance. (A: ~17,500 calendar years ago)
(Date calibration mine (INTCAL04) Very aggravating that carbon date calibration still isn't mandatory nowadays)
Apparantly it was rather common that ice and spruce were much closer together (horizontally) than today. So I repeat, what is wrong with this picture?
Old Dec5-07, 05:15 PM                  #16
jim mcnamara
Recognitions:
If the trees were either submerged or subsumed by wet soils, they could remain 'bendable' essentially as long as there were no major chemical changes to the lignin - the compound that glues cellulose fibers together. In fact, there is a Lake Superior project in the US which is salvaging submerged logs left over from the massive tree cutting of the 1850-1880's. The wood is essentially perfect, especially for getting wide pieces of straight grained spruce for violins, cellos, etc. FWIW Stradivarius and violin makers of the 17th & 18th C used the same procedure - letting logs sink into a pond to keep them usable for a long period of time.
Unless this is a construction site or a dump or anything else to link what we see to human activity, then there is nothing wrong with the picture. IMO.
What I'm saying - consider this scenario
tree slumps off wet hill into a bog or stream and is submerged. Several hundred years later the glacial till covers it and the compression phase begins. Falling and bending do not have to happen at the same time. If the water is not hard or laden with metal salts, then mineralization of the wood will not occur. Leaving the wood flexible for long periods of time.
If you are trying to use this for dating something, you have a bad assumption. IMO. Tree death date != bending date is the assumption I am making. You are assuming that bending and tree death are nearly concurrent, it seems. Correct me where I am wrong.
You are also saying there is no carbon dating data to clear things up.
image image
Reply
Thread Tools
Similar Threads for: log - rock - scissors
Thread Thread Starter Forum Replies Last Post
80s Rock Cyrus General Discussion 35 Apr7-07 07:40 PM
The third rock wolram General Discussion 4 Aug26-06 03:21 AM
Rock Paper Scissors in Court! mattmns General Discussion 3 Jun8-06 07:50 AM
rock, paper, scissors revisited DaveC426913 General Discussion 645 May12-06 08:33 PM
Rock, Paper, Scissors Mattara General Discussion 28 Feb15-06 01:59 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
