So the question would be:What is the difference between absolute value and norm?
  • Context: Undergrad
  • Thread starter Thread starter lampshade
    Mean
The discussion centers around the distinction between absolute value and norm, particularly in the context of mathematical notation used in integrals and various mathematical texts. Participants explore the meanings and contexts in which these terms are applied, including one-dimensional and multi-dimensional cases.
  • Some participants suggest that the notation |f(t)| in integrals typically refers to absolute value, while others indicate it may also represent magnitude depending on context.
  • One participant mentions that absolute value can be viewed as the magnitude of a number, implying a connection between the two concepts.
  • Another participant notes that the notation ||x|| generally denotes the two norm, but |x| can sometimes represent other norms, creating potential ambiguity.
  • There is a discussion about the various types of norms, including Euclidean norms, taxi cab norms, and infinity norms, with one participant emphasizing that absolute value usually refers to the two norm.
  • One participant points out that absolute value is a one-dimensional case of a norm, but there are many different kinds of norms that can be applied in higher dimensions.
  • Concerns are raised about the potential for confusion when |x| is used to denote different types of norms, semi-norms, or estimates.
Participants express a mix of agreement and disagreement regarding the meanings of absolute value and norm, with some asserting they are the same while others highlight the nuances and variations in usage across different contexts.
Participants note that the interpretation of notation can depend heavily on context, and there may be missing assumptions or definitions that could clarify the discussion.
lampshade
Hello,
I don't know if this is general math or not, but I know it is a simple question that I just don't get so I put it in this forum.
I'm kinda rusty at this, but I came across an equation in a book on wavelets that uses the notation
| f(t) |
inside an integral and I"m not sure what they mean. What does the | | notation mean? Do they mean absolute value? Are they using it to mean magnitude but just not using the || a || notation I'm more familiar with?
they use it in an integral from negative infinity to infinity of |f(t)|dt
thanks in advance,
Lampshade
After studying it some more, I think they do actually mean the absolute value and nothing else. I'm still a bit shaky though so respond with insights if you have any, please.
Yes, it means absolute value.
In general you should be able to tell from the context which is meant. Many books with use the same notation for absolute value as well as magnitude.
Really, because they are the same. The Absolute value can be seen as the magnitude of the number.
That is if f is a numerical function. I think k3N70n was referring to the situation where f is a vector function. Many textbooks use | | for "magitude" (length) of a vector as well as absolute value of a number.
||x|| generally means the two norm. |x| can also be the two norm, but sometimes it stands for something else.
You should never assume [tex]\|x\|[/tex] is the [tex]L^2[/tex] norm, unless the author has stated that explicitly. It just means 'the norm of x'. Which norm should be clear from the context; if not, go back a few pages and try to figure it out.
I don't think I have ever seen |x| used for any norm other than the standard Euclidean norm for vectors or the magnitude of a real number/complex number/quaternion (which are essentially the Euclidean norm anyway). It would be bizarre if someone used that for an L^p norm.
whats the difference between absolute value and norm? in my linear algebra book it is stated that absolute value is the one dimensional case of the norm.
There are many different kinds of norms. The one we are most used to is the euclidean, or two norm. 99 times out of a hundred, absolute value refers to the two norm, which for any vector is sqrt(x*x). (I cheat with my notation here). However, it's not the only possible one.
There are taxi cab norms, infinity norms and all other kinds of p-norms. To make a long story short, I think if you simply pick any positive definite matrix A, then (x*Ax)^(k) will do as a norm.
Then there are also semi norms, which can be even more complicated. I've seen |x| used to denote norms, semi-norms and estimates of all kinds.
The basic thing all of these operations have in common is that they take an object, possibly very complicated, i.e. complex number, vector, (quaternion?), function, distribution, whatever, and they return a (positive?) real number that gives you an idea of that objects "size".
