Why aren't all insulators transparent?
The discussion revolves around the question of why not all insulators are transparent, exploring the relationship between material properties, electron behavior, and light interaction. Participants inquire about the transparency of specific materials like SiO2 and Si, as well as the characteristics of conductors and insulators.
  • Some participants propose that the interaction of conductors with electromagnetic waves prevents transmission, leading to questions about the transparency of insulators.
  • Others argue that insulators do not necessarily have "opposite properties" to conductors and can still be opaque in the visible range.
  • Several participants express curiosity about the transparency of certain materials, questioning why SiO2 is transparent while Si is not.
  • There are inquiries about the existence of transparent conductors and whether insulators can exhibit luster and reflectivity similar to metals.
  • One participant notes that transparency is controlled by the behavior of outer shell electrons and mentions that luster is related to surface properties.
  • Another participant suggests that metals can be transparent at energies above the plasma energy, linking this to electron behavior.
  • A later reply introduces the idea of explaining transparency through photon-electron interactions and scattering, inviting corrections to this perspective.
Participants express a range of views on the relationship between electron behavior and material transparency, with no consensus reached on the underlying principles or specific examples discussed.
Some claims about the properties of materials depend on definitions and may not account for all conditions or exceptions, such as the specific energy levels at which materials may exhibit transparency.
yert
As I understand it, conductors interact with EM waves (light) in such a way that
prevents transmission through the conductive material.
Given this, why aren't all insulators transparent?
Why is SiO2 transparent, but Si by itself is not?
Any and all information helpful.
TIA,
yert
Science news on Phys.org
Why should they be? Should insulators have "opposite properties" to every typical property of a conductor? Even if insulators interact with EM waves in a completely different way, can they still not be opaque over the visible range?
The properties of a compound have nothing to do with the properties of the elements it is composed of.
PS: You might want to check out post #4 here: https://www.physicsforums.com/showthread.php?t=104715
Transparency
I am trying to understand why some types of matter are transparent and why
other types are not, that is my real question.
Now, there are other questions I have that go along with this.
For example, are there any known conductors that are transparent?
Are there insulators that have a luster (like metals) and are reflective (like metal)?
I had understood it to be that the "behavior" of the electrons determine the properties of the compound. Metals with free electrons in their outer most shell tend to be the best conductors, stable elements with all electron shells stable (lowest energy state) tend to be good insulators. relection and luster is just another property due to electron behavior.
My explanation may not be completely correct so I suggest wikipedia and check out the references they use.
Transparency is all controlled by the outer shell of electrons.
There's no transparent conductor except for liquids.
Luster is other phenonmenon : reflection. It depends more on the surface properties of the material.
Did you read the FAQ that was pointed out to you?
Zz.
Transparency
I did read the message referred to me, but have not read the FAQ, yet.
Metals are transparent at energies above the plasma energy.
As mentioned above, it's all to do with electrons in the material.
Just a note.
It is also possible to explain this phenomenon by considering light as a particle.
The amount of scattering that arises due to photon-electron interactions determines the opacity of the material.
Correct me if I'm wrong.
10K
  • · Replies 18 ·
9K
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 17 ·
