Can Aluminum at 90 Degrees Celsius Melt 10 Grams of Ice?
The discussion focuses on calculating the mass of aluminum required at 90 degrees Celsius to melt 10 grams of ice at 0 degrees Celsius. The key equations involve the specific heat capacities of aluminum (0.9 J/g°C) and ice (2.1 J/g°C), along with the latent heat of fusion for ice, which is 333.7 kJ/kg. To find the solution, participants emphasize calculating the heat energy (Q) needed to melt the ice and then using this value to determine the mass of aluminum by applying the temperature change (delta T) of 90 degrees Celsius.
  • Understanding of specific heat capacity and latent heat concepts
  • Familiarity with the equation Q = (m)(c)(deltaT)
  • Knowledge of the specific heat capacities of aluminum and ice
  • Basic algebra skills for solving equations
  • Calculate the heat energy required to melt 10 grams of ice using the latent heat of fusion
  • Learn how to apply the heat transfer equation Q = (m)(c)(deltaT) in practical scenarios
  • Explore the concept of thermal equilibrium in heat transfer problems
  • Investigate the effects of temperature on the specific heat capacities of different materials
Students studying thermodynamics, physics enthusiasts, and educators looking to enhance their understanding of heat transfer and phase changes in materials.
BlueSkyy
Melting Ice With Aluminum??
How many grams of aluminum at 90 degrees C would have to be dropped into a hole in a block of ice at 0.0 degrees C to melt 10 g of ice?
Q = (m)(c)(deltaT)
c of aluminum = 0.9
c of ice = 2.1
c of water = 4.186
333.7 kJ is needed to get past the ice/water boundary
I've tried setting up a few different equations, like:
(.01 kg)(2.1)(+45) + (x kg)(0.9)(-45) = 0
(.01 kg)(2.1)(+45) + 333.7 + (x kg)(0.9)(-45) = 0
and a few others I don't have on hand, but I can't seem to get the correct answer. What do I use for delta T? Am I even doing this right at all?
Thanks for your help.
No, I think you are missing it. First calculate the heat energy Q needed to melt 10 g of ice. Your latent heat of fusion should read 333.7 kJ/kg. Then solve for the mass of aluminum having this value of Q, using deltaT=90C (since the final temp of the Al is 0C once it's done its job).
  • · Replies 17 ·
