How Is Force Calculated to Maintain Position on an Inclined Wedge?
The problem involves a block of mass (m) placed on a triangular wedge of mass (M) at an angle (α). The task is to determine the force (F) required to keep the smaller block stationary on the wedge, considering the coefficient of static friction (μs) and gravitational effects. The discussion includes the need for a free-body diagram (FBD) to analyze the forces acting on both blocks.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Newton's laws, particularly the first and second, and the necessity of a free-body diagram to identify forces. There are attempts to resolve forces into components and establish equilibrium conditions. Some participants express uncertainty about the correct application of forces in the FBD.
The discussion is ongoing, with participants sharing insights about the forces involved and the need for clarity in the free-body diagram. There is recognition of the need to resolve forces into components, but no consensus has been reached on the correct setup or solution approach.
Participants note the importance of documenting all relevant laws and theories, such as Newton's laws and the definition of friction. There is an emphasis on ensuring that all forces are accounted for in the FBD, which remains a point of confusion.
amajorflaw
a block of mass (m) is placed on a bigger triangular shaped block with a mass (M). The wedge is of angle (α) . The coefficient of static friction between the two blocks is μs . What must the force (F) be in order to keep the smaller block at the same height on the wedge-shaped block? The answer is an equation in terms of the coefficient of friction, M, m, the angle and the gravitational acceleration. A FBD is also required. All laws must be documented and used properly.
Newton's 1st Condition
Gravitational Acceleration
Definition of Friction
I have the answer, but I'm having trouble getting to it.
The answer to the problem:
F = (M+m)((sinα-μscosα/cosα-μssinα))g
You are missing another important theory, Newton's 2nd. Also, you should draw a free-body diagram to clearly communicate all of the forces being exerted on this body.
Casey
The acceleration of the system = a = F/(M + m )
the forces acting on the mass m are mg and ma. Resolve them into the components parallel and perpendicular to the surface of the wedge and find the condition for the equilibrium.
Yeah that's where I'm stuck. I'm not sure where all of the forces apply on the two blocks, so my free body diagram is wrong. It's not the equations that are troubling me. It's getting all of the parts to the FBD that is troubling me.
I'm not sure where all of the forces apply on the two blocks Both the blocks experience equal force in thr horizontal direction. You have to draw FBD for the body of mass m. As I have already mensioned, resolve them into the components parallel and perpendicular to the surface of the wedge and find the expression for a.
mgSin(alpha)-μsmgCos(alpha)=maCos(alpha)-μsmaSin(alpha)
forces acting on m in equilibrium.
forces due to gravity = forces due to F.
That is correct. You can simplify this as g[Sin(alpha)-μsCos(alpha)]=a[Cos(alpha)-μsSin(alpha)]. Now substitute the value af a
  • · Replies 37 ·
  • · Replies 25 ·
