Evaluating integrals or not?
by pivoxa15
Tags: evaluating, integrals
pivoxa15
pivoxa15 is offline
#1
Dec6-07, 03:40 AM
P: 2,268
Why are some integrals not able to be evaluated?
i.e. the integral of (1+1/x^4)^(1/2) is impossible to evaluate exactly from 0 to 1. Why??
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Hurkyl
Hurkyl is offline
#2
Dec6-07, 03:54 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
It's hard to answer your question without knowing just what you mean by "evaluated", "able", and "why".
HallsofIvy
HallsofIvy is offline
#3
Dec6-07, 04:07 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
If you mean "find an expression for the anti-derivative in an elementary form", that is true for almost all integrable functions. the problem is that we simply don't know enough functions. By "elementary functions" we typically mean rational functions, radicals, exponentials and logarithms, and trig functions. That is just a tiny part of all possible functions, even all possible analytic functions.
In a deeper sense, the problem is that while we have "formula" for the derivative, there is no "formula" for the anti-derivative; it is simply defined as the "inverse" of the derivative. And "inverses" are typically very difficult. If we define [itex]y= x^5- 3x^3+ 4x^3- 5x^2+ x- 7[/itex], the direct problem, to "evaluate" the function (Given x, what is y?) is relatively simple. The "inverse" problem, to "solve the equation" (Givey y, what is x) is much harder
pivoxa15
pivoxa15 is offline
#4
Dec6-07, 06:06 AM
P: 2,268
Quote Quote by Hurkyl View Post
evaluate by integrating from 0 to 1. which I have added in the OP.
able as you computing it exactly.
why as in why is it not able to be computed exactly.
pivoxa15
pivoxa15 is offline
#5
Dec6-07, 06:08 AM
P: 2,268
Quote Quote by HallsofIvy View Post
So we will have an infinite series as an antiderivative for the function? If so then we can compute the series? It might diverge?
morphism
morphism is offline
#6
Dec6-07, 06:14 AM
Sci Advisor
HW Helper
P: 2,020
Well, your example diverges.
[tex]\int_0^1 \sqrt{1 + \frac{1}{x^4}} \, dx = \int_0^1 \frac{\sqrt{x^4 + 1}}{x^2} \, dx \geq \int_0^1 \frac{1}{x^2} = \infty[/tex]
HallsofIvy
#7
Dec6-07, 07:58 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
Quote Quote by pivoxa15 View Post
Given an analytic function to be integrated, we certainly can calculate its Taylor's series and integrate that term by term to get a power series for the anti-derivative. If I remember correctly, it should converge on the same radius of convergence as the original function.
Of course, not all functions of interest are analytic- i.e. have a Taylors series that converges TO the function on some interval around the central point.
Hurkyl
Hurkyl is offline
#8
Dec6-07, 03:45 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
What precisely do you mean by "compute"?
If you mean "write in decimal notation with finitely many digits", then isn't the answer obvious?
If you mean "write down an algorithm that, given an integer n, outputs the n-th digit in its decimal representation", then it is computable.
Register to reply
Related Discussions
Evaluating Indefinite integrals Calculus & Beyond Homework 2
Evaluating Functional integrals Beyond the Standard Model 3
Evaluating Line Integrals Calculus & Beyond Homework 1
Evaluating these integrals.. Introductory Physics Homework 4
Help evaluating these integrals Calculus 1
