Understanding L'Hopital's Rule and Limits at Infinity
  • Thread starter Thread starter ada0713
    Limit
The discussion revolves around evaluating the limit of the expression (x^1000 + 10) / (e^x + 1) as x approaches infinity, specifically focusing on the application of L'Hopital's Rule and the behavior of polynomials versus exponential functions at infinity.
  • Participants discuss the application of L'Hopital's Rule due to the indeterminate form of infinity/infinity. There are attempts to clarify the reasoning behind the limit approaching zero and the implications of differentiating the numerator and denominator multiple times.
Some participants have provided insights into the growth rates of polynomials versus exponentials, suggesting that the exponential function will dominate as x approaches infinity. However, there is still exploration of the mechanics of L'Hopital's Rule and the specific limit evaluation.
Participants are navigating the complexities of applying L'Hopital's Rule and the assumptions regarding the growth rates of functions without reaching a definitive conclusion.
ada0713
Lim[x to infinity] (X^1000+10)/(e^x+1)
It seems like the answer is zero but I'm not exactly sure why it is.
if you use lhopital's rule you get both numerator and demoniator huge numbers
(or is it right that if you take the derivative for both of them you get a constant
on the top and infinity at the bottom?)
Please help me!
from what I'm seeing
[tex]\lim_{x \rightarrow \infty}\frac{x^{1000}+1}{e^{x}+1}[/tex]
correct?
so we have infinity/infinity and thus we can apply L'Hopital's method. well from what you said, it's true, we will get huge numbers on the numerator but if we do this 1000 times, we'll eventually get
[tex]\lim_{x \rightarrow \infty}\frac{1000!}{e^{x}}[/tex]
our limit is 0 b/c the derivative of e is simply itself.
l'hopital's rule is if the numerator and denominator both go to infinity or 0 then if you take the limit of there ration it's equal to the limit of the ratio of there derivatives. In this case both numerator and denominator go to infinity so you can use this rule.
Exponentials grow much faster than any finite polynomial. It's not so easy to actually calculate when the denominator becomes larger than the numerator (You need to use the Lambert W function), but as long as we know exponentials grow faster than polynomials, as x --> infinity the quotient goes to 0.
