FM Radio Receiver
by misz_univerze
Tags: radio, receiver
misz_univerze
misz_univerze is offline
#1
Dec8-07, 02:14 AM
P: 3
The objective is to "design and construct an FM radio receiver" that is able to tune to commercial FM radio broadcast channels spanning from "87.5 MHz to 108 MHz", and to produce audible demodulated output.
can anybody help me with a simple circuit for this assignment with proper values for the caps n other components...
n wat is the formula i can use to calculate the proper values for this components for the frequency specified above...
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
ranger
ranger is offline
#2
Dec8-07, 02:58 PM
PF Gold
ranger's Avatar
P: 1,686
Well, if we give you everything, you won't be designing and constructing an FM radio receiver, with emphasis on design, right?
The way your question is structured, it sounds like you have no idea what goes into building such a circuit. Is this true? Can you at least break this circuit into smaller subcircuits?
misz_univerze
#3
Dec8-07, 03:30 PM
P: 3
ok... ur very right... i seriously have no idea where to start n where to head... im in need of serious guidance... i found something from this link i've attached below... but im not sure how to relate it wit the question i have been given... plz help me through this task... http://www.somerset.net/arm/fm_only_...tor_radio.html
Danger
Danger is offline
#4
Dec8-07, 05:03 PM
PF Gold
Danger's Avatar
P: 8,961
FM Radio Receiver
Welcome to PF, Misz.
As Ranger indicated, solutions to problems of an academic nature are not provided here. You will get guidance only. It isn't PF's mandate to solve people's problems, but to help them solve them on their own initiative. The exception to that is when someone with a real-life problem needs assistance to dispell it; then we brainstorm it.
Since this is a sore point with me, I will ask if the solutions are in your textbooks or course material?
This might be due to me being a baby-boomer, but it seems to me that lately a lot of test questions are beyond the scope of what has been taught. I never saw an exam question (or even pop quiz) that dealt with anything that we hadn't already covered in class.
ranger
ranger is offline
#5
Dec8-07, 05:48 PM
PF Gold
ranger's Avatar
P: 1,686
Quote Quote by misz_univerze View Post
Well an FM receiver is circuit that consists of many of many other major subcircuits. I suggest that you practice the "divide and conquer" rule. Take your FM receiver, break it up into its major parts. The block diagram from wiki should get you started. Surely you've covered the concepts and applications of filters, amplifiers, etc?
Is it a requirement for you to use discrete components only? Using an IC such as the TDA7088 may help you out.
Also, try google images and see if you can find some schematics on FM receivers. You can observe techniques employed from RF filter to the audio output.
http://en.wikipedia.org/wiki/Radio_receiver_design
http://home.hetnet.nl/~a.van.waarde/id21.htm
http://stuff.nekhbet.ro/2006/06/25/h...g-tda7088.html
http://www.circuits.8m.com/Fm-radio.htm
misz_univerze
#6
Dec9-07, 02:18 AM
P: 3
ok... the things u gave me... look pretty complicating.. we were to told to build a simply circuit... dats it... so im not sure if i can use a TDA7088...
music-radio
music-radio is offline
#7
Jul15-09, 05:11 AM
P: 1
hi,
i am having same problem and looking for a solution
thanks
Register to reply
Related Discussions
Radio transmitter and Receiver Engineering Systems & Design 3
Designing a FM radio receiver Introductory Physics Homework 1
a question for hams/radio heads: radio astronomy Electrical Engineering 6
Why cant u make radio transmitter that transmit visible light instead of radio waves? Introductory Physics Homework 1
Campus FM Radio or Community FM Radio Electrical Engineering 3
