Equivalent acceleration of an accelerometer
The discussion revolves around the equivalent acceleration of an accelerometer, focusing on the interpretation of forces acting on the seismic mass and the implications of inertial versus non-inertial reference frames. Participants explore the mathematical formulation of these forces and the resulting outputs of the accelerometer under different conditions.
  • Some participants express confusion regarding the notation used for forces and accelerations, particularly the meaning of negative signs in the equations.
  • One participant suggests that the negative signs in the equations may arise from balancing inertial forces with restoring forces in the accelerometer, indicating a relationship between the direction of acceleration and the movement of the mass.
  • A question is raised about the output of an accelerometer when swung in a positive direction, seeking clarity on whether the output would be positive or negative.
  • Another participant notes that the output can vary based on convention, depending on whether it reports the calculated acceleration of the system or the apparent acceleration of the mass in a non-inertial frame.
  • Discussion includes the interpretation of gravitational acceleration (g) in different frames, with some participants questioning how it should be reported in inertial versus non-inertial contexts.
Participants do not reach a consensus on the interpretation of the signs in the equations or the output of the accelerometer. Multiple competing views remain regarding the calibration and reporting of acceleration in different frames.
There are unresolved assumptions about the definitions of inertial and non-inertial frames, as well as the calibration of the accelerometer, which may affect the interpretation of outputs and the sign of gravitational acceleration.
ylim
Hi there,
I am reading this old journal and found this formulaes.
forces on the seismic mass, expressed in inertial reference coordinates, are given by Newton's law as
sum of force in x direction = m * x''
sum of force in y direction = m * y'' = Fy = mg
the equivalent acceleration of the accelerometer are
ax = -F/m = -x''
ay = -F/m = -y'' - g
i am rather concerned with the change in sign direction. i vaguely understand the concept of inertial and non inertial ref frame. but i don't know why it will cause a diff to the axial acceleration. hope to hear from someone.
I'm not sure I understand your notation (Fy is force in the y direction, and ax and ay are accelerations in the x and y directions, right? x" is also acceleration in x direction?)
In any case, however, the negative signs probably come from balancing the inertial force on the test mass, which results from the external acceleration that you're measuring, with the restoring force of the spring (assuming that's what supplies the balancing force in the accelerometer) - equal and opposite forces, you know. In other words, if the system is accelerating to the right (positive direction), the mass will swing to the left (negative direction), so it applies a force in the negative direction. If you want to think about the non-inertial frame of the accelerometer, it just means that a tiny observer in that frame would see the mass move to the left and interpret that as a force (and acceleration) to the left.
That's my guess, anyway - it's kind of hard to be sure since you haven't given much explanation.
this will come to a qn which i have, i have an accelerometer, when i swing it to its positive direction, will it be a positive or a negative output?
so (to be more specific) to a right accelerating accelerometer (positive is right), what should be my output? positive or negative?
- Yes.
i guess we can see it when one is a in plane, when it is accelerating, we cannot anticipate/follow up, so we get push back to our seats? the seats gives the 0 opposite force, which is the spring in your explanation?
BUT, the weird thing is the sign of the g. which is -g? in the case of a resting accelerometer, in a inertial ref frame, it should be -1g. but in a non-inertial, it should be +1g? I notice this from a analog devices (crossbow) development board i have.
The output can be either - it's just a matter of convention. If the output reports the calculated acceleration on the whole system, then it will be positive (in your example). If it reports the apparent acceleration of the mass in the non-inertial internal system (which is the "raw" information it measures) and leaves you to convert that back to the system acceleration, then it would report a negative (left) acceleration.
Yes, I think you're correct about the plane example: the plane accelerates forward during take-off, but inside, in our non-inertial frame, we feel a force that accelerates us backwards into the seat. We stop when the seat cushion is compressed enough to provide an opposing force equal to the inertial force of our bodies, and if the cushion happened to calibrated to provide a nice measurement of that compression, we could determine the rate of acceleration of the plane.
As for the factor of g, that has to do with whether we're reporting the "sensed" acceleration or the "true" acceleration. This in turn depends on how the accelerometer is calibrated, i.e. under what circumstance does it read 0 vertical acceleration. It could be when it is at rest, i.e. when it senses an acceleration of -g, or it could be when it is actually falling at an acceleration of -g, so it senses no net acceleration.
  • · Replies 117 ·
10K
