Thread Closed
Gravitational Pull Question
Share Thread Thread Tools
Dec9-07, 09:49 PM   #1
On the way to the moon, the Apollo astronauts reach a point where the Moon's gravitational pull is stronger than that of the Earth's.
Find the distance of this point from the center of the Earth. The masses of the Earth and the Moon are 5.98e24 Kg and 7.36e22 Kg, respectively, and the distance from the Earth to the Moon is 3.84e8 m.
Answer in units of m.
2. Relevant equations
F=G(m1)(m2)/r(squared)
Where F is force of gravity, G is gravitational constant, m1 is mass of one object, and m2 is mass of second object. And r(squared) is the radius from center to center.
F(C)=mv(squared)/r
where F(c) is centripetal force, m is mass of an object (in Kg), v(squared) is the linear speed of an object (in m/s), and r is the radius from the center of the object being orbited around.
g=Gm1/r(squared)
g is acceleration due to gravity, G is gravitational constant,m1 is mass of object causing gravity, and r(squared) is radius from center to center.
V(squared)=Gm1/R
V(squared) is linear speed, G is gravitational constant, m1 is object causing gravity, and r is radius.
3. The attempt at a solution
I tried using the equation g=Gm1/r(squared) for each the earth and the moon, and setting them equal to each other, but that didn't really work out.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec9-07, 09:56 PM   #2
Setup an inequality
[tex]\frac{G(m_{moon})(m_{apollo})}{r_{moon to apollo}^2} > \frac{G(m_{earth})(m_{apollo})}{r_{earth to apollo}^2}[/tex]
Stuff cancels out and you're left with:
[tex]\frac{m_{moon}}{r_{moon to apollo}^2} > \frac{m_{earth}}{r_{earth to apollo}^2}[/tex]
We know that the distances are related because the earth and the moon are a set distance apart and the sum of the distance between the astronauts and the moon and earth must be the same as the distance between the earth and moon. If you find when the two are equal you when when the moons gravitational pull will be greater
Dec9-07, 10:04 PM   #3
Recognitions:
Homework Helper Homework Help
If x is the distance from the earth at which the gravitational pull due the earth and moon are equal then GMe/x^2 = GMm/(3.84e8 - x)^2. Now solve for x.
Dec9-07, 10:18 PM   #4
Thankyou for the help. I got the answer now, and it was correct.
Thread Closed
Thread Tools
Similar Threads for: Gravitational Pull Question
Thread Forum Replies
gravitational pull General Discussion 10
Earths gravitational pull General Physics 4
Gravitational pull of moon Introductory Physics Homework 1
Gravitational pull of the sun Introductory Physics Homework 2
equal gravitational pull Introductory Physics Homework 8
