Symmetry of mass distribution producing radial gravitational force field
The discussion revolves around the conjecture that only a spherically symmetric mass distribution can produce a radial gravitational force field, as described by Newton's law of gravitation. Participants explore the implications of this conjecture through mathematical reasoning and physical principles, addressing both theoretical and conceptual aspects.
  • One participant conjectures that only spherical symmetric mass distributions can yield radial gravitational force fields.
  • Another participant references Gauss' law to argue that if the gravitational field depends only on the radial distance, then the mass distribution must also be spherically symmetric.
  • A participant clarifies that they are considering a radial field as a scalar field multiplied by a vector pointing outward, suggesting that the source must be spherically symmetric.
  • There is a discussion about the curlless nature of the gravitational field and its implications for the mass distribution, with one participant expressing uncertainty about whether the gravitational field is indeed curlless.
  • Another participant challenges the assumption of a curlless gravitational field, noting that non-zero divergence at points of mass density complicates the argument.
  • Some participants discuss the relationship between conservative fields and the curl of the gravitational field, asserting that gravitational fields are conservative and thus curl-free.
  • There is a debate about the mathematical proof of the impossibility of circulating force fields and what constitutes a valid mathematical argument against such distributions.
  • One participant provides a detailed mathematical derivation to support the claim that the gravitational field must be curlless, referencing the integral formulation of the gravitational field.
Participants express differing views on the assumptions regarding the curl of the gravitational field and the implications for mass distribution. There is no consensus on whether the conjecture is proven or disproven, and the discussion remains unresolved regarding the mathematical proof of the impossibility of circulating force fields.
Participants acknowledge the need for further clarification on the mathematical arguments related to curl and divergence, as well as the conditions under which gravitational fields are considered conservative. Some assumptions about the nature of the gravitational field and its mathematical properties remain unverified.
mma
I conjecture that only spherical symmetric mass distribution can produce radial gravitational force field (according Newton's law of gravitation).
Can anybody prove or disprove this conjecture?
If [itex]\mathcal{G}(r)[/itex] is the gravitational field, that we assume depends only on r, then the field and the mass distribution are related by Gauss' law:
[tex]\nabla\cdot\mathcal{G}(r)=\rho(r,\theta,\phi)[/tex]
clearly this implies that rho depends only on r... i.e., the mass distribution is sperically symmetric.
clearly this implies that rho depends only on r... i.e., the mass distribution is spherically symmetric.
I don't suppose that the gravitational field depends only on r. That's why I wrote "radial" and not "central". Radial means here that there is a scalar field s(p) and a point o that our force field is F(p) = s(p)(p-o) (p and o are space points, space is regarded to an 3-dimensional affine space). The conjecture is that the source of such gravitational field can only be a spherically symmetric mass distribution.
Oh, I understand. In this case, we can assume o is the origin. Then the hypothesis is that
[tex]\mathcal{G}=s(r,\theta,\phi)r\hat{r}[/tex]
and now the curlless nature of [itex]\mathcal{G}[/itex] (gravitostatic) gives that s is theta and phi independent. Then use Gauss's law as used as in post #2 gives that rho is theta and phi independent.
This proof seems very impressive and elegant!
But, are you absolutely sure that [itex]\mathcal{G}[/itex] is curlless?
I know that it must be curlless if it has a potential, and it must have a potential if it's divergence is zero. But it's divergence isn't zero at points where the mass density isn't zero.
Not 100% sure... for that I'd have to pick up my E&M book and confirm that all the steps taken to derive curl(E)=0 transfer to gravity, but I don't have my physics book anywhere near me. But I'm 95% sure.
I'm afraid that if I take an arbitrary smooth [itex]\mathcal{G}[/itex] vector field, then it's divergence is just a mass distribution which generates [itex]\mathcal{G}[/itex]. If [itex]\mathcal{G}[/itex] has a non-vanishing curl, then this example will be in your 5%.
Since we forgot the mathematical argument for curl(E)=0, look at it this way. It is a know fact from physics that gravitational fields are conservative. And we remember that this statement is equivalent to curl(G)=0. Voilà.
Yes, of course, a circulating force field would violate the conservation of energy. But how can we prove mathematically that it is impossible? What excludes such density distributions?
Why does the violation of conservation not count as a mathematical proof?
Just grab Griffiths and flip through the first few pages. Or Simon's (Simmon?) mechanics.. and the chapter on gravitational fields.
I've got the correct answer:
According Newton's law the gravitation al field of a given [tex]\rho[/tex] mass distribution is:
[tex]\mathcal{G}(p)=\int_{R^3}{\rho(q)\frac{(p-q)}{|p-q|^{3}}{dq}[/tex]
(the integral is a volume integral on the whole 3-dimensuional space)
Taking an arbitrary smooth closed curve [tex]\mathcal{C}[/tex] , the circulation of [tex]\mathcal{G}[/tex] on it is:
[tex]\int_{\mathcal{C}}{\int_{R^3}{\rho(q)\frac{(p-q)}{|p-q|^{3}}{dq}}{dp} <br /> <br /> = \int_{R^3}\rho(q){\int_{\mathcal{C}}{\frac{(p-q)}{|p-q|^{3}}{dp}}{dq}[/tex] (the integrals commute according Fubini's theorem)
and the inner integral is zero for every q, because the [tex]\frac{(p-q)}{|p-q|^{3}}[/tex] function has a potential, hence it is circulationless. So, our [tex]\mathcal{G}[/tex] is also circulationless, i.e. curlless.
With this small supplement, your proof is perfect, thank you, quasar987!
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 32 ·
