What is the Convergence of the Fibonacci Sequence?
  • Context: Graduate
  • Thread starter Thread starter al-mahed
    Limit
The discussion revolves around the convergence of the ratios of consecutive terms in the Fibonacci sequence, specifically whether the limit of the ratio \( \frac{a_n}{a_{n-1}} \) approaches a specific value as \( n \) approaches infinity. Participants explore various mathematical approaches and proofs related to this convergence.
  • One participant proposes a proof involving the relationship \( a_n^2 = a_{n-1} a_{n+1} \pm 1 \) and seeks to establish limits for the ratios \( \frac{a_n}{a_{n-1}} \) and \( \frac{a_{n+1}}{a_n} \).
  • Another participant questions the interpretation of convergence, suggesting that proving \( \lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n} = 1 \) would imply the sequence approaches a final value, which is not the case.
  • Some participants clarify that the limit expressions must not include subscripts dependent on \( n \) and discuss the implications of this requirement.
  • There is a discussion about whether the limit can exist if the sequence oscillates or is bounded, with references to the behavior of other functions like \( \sin(x) \).
  • One participant suggests that the sequence is increasing and bounded, proposing that this could lead to a conclusion about convergence.
Participants express differing views on whether the limit of the ratios converges to a specific value, with some asserting that the limit cannot be presumed to exist while others explore conditions under which it might. The discussion remains unresolved regarding the convergence of the sequence.
Participants note that the proof methods depend on the definitions and assumptions made about the Fibonacci sequence and its properties. There are unresolved mathematical steps and conditions that affect the conclusions drawn.
al-mahed
Hi,
I would like some help in this problem:
given the fibonacci sequence 1,2,3,5,8,13...
we know that a_n/a_(n-1) --> phi when n --> [tex]\infty[/tex]
I have tried a new proof in these terms:
My goal is to prove that when n --> [tex]\infty[/tex], a_n/a_(n-1) = a_(n+1)/a_n in the limit
I have notice that a_n^2= a_(n-1)*a_(n+1) [tex]\pm[/tex] 1 for some values
Dividing both sides of the equation by a_n*a_(n-1)
[tex]\frac{a_n}{a_n_-_1}[/tex] = [tex]\frac{a_n_+_1}{a_n}[/tex][tex]\pm[/tex] [tex]\frac{1}{a_n*a_n_-_1}[/tex]
I want to find the limits, because the second term in the right side of the equation --> 0 when n --> [tex]\infty[/tex]
But I don't know if the equation above is valid for all n, so I'll prove this by induction as follows:
supose that the expression above is valid for some n
by definition a_(n+1)=a_n + a_(n-1)
a_n^2= a_(n-1)*[a_n + a_(n-1)] [tex]\pm[/tex] 1 ==> a_n^2 - a_(n-1)^2= a_(n-1)*a_n [tex]\pm[/tex] 1 ==>
==> [a_n + a_(n-1)]*[a_n - a_(n-1)] = a_(n-1)*a_n [tex]\pm[/tex] 1
by definition a_n - a_(n-1)= a_(n-2) ==>
==> [a_n - a_(n-1)]* a_(n-2) = a_(n-1)*a_n [tex]\pm[/tex] 1
by definition a_n = a_(n-1) + a_(n-2) ==>
==> [a_n - a_(n-1)]* a_(n-2) = a_(n-1)*[a_(n-1) + a_(n-2)] [tex]\pm[/tex] 1 ==>
==> a_(n-2)*a_n + a_(n-1)*a_(n-2) = a_(n-1)^2 + a_(n-1)*a_(n-2) [tex]\pm[/tex] 1 ==>
==> a_(n-1)^2 = a_(n-2)*a_n [tex]\pm[/tex] 1
compare the two expressions
most generally we have
[tex]\{a}{_i}{^2}[/tex]} = [tex]\{a_i_-_1*a_i_+_1}[/tex]} [tex]\pm[/tex] 1, with i=2,3,4,5,6...,n
proving by induction (sorry about the english and notation)
Hence,
Lim[tex]\{_n_-_>_i_n_f_i_n_i_t_y}[/tex][tex]\frac{a_n}{a_n_-_1}[/tex]} = Lim[tex]\{_n_-_>_i_n_f_i_n_i_t_y}[/tex][tex]\frac{a_n_+_1}{a_n}[/tex][tex]\pm[/tex] [tex]\frac{1}{a_n*a_n_-_1}[/tex]}
Lim[tex]\{_n_-_>_i_n_f_i_n_i_t_y}[/tex][tex]\pm[/tex] [tex]\frac{1}{a_n*a_n_-_1}[/tex]} = 0
in the limit [tex]\frac{a_n}{a_n_-_1}[/tex] = [tex]\frac{a_n_+_1}{a_n}[/tex]
Why this do not prove the convergence?
I'm not sure what you're trying to prove. When you say convergence, are you trying to prove that in the [tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n}[/tex] = 1?
That would imply that the sequence of numbers goes to some final value, although the sum of those numbers would still diverge since that number isn't 0.
The sequence grows uniformly, a_n+1 > a_n, so a_n+1/a_n > 1 always. What you've done is prove that
[tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n}[/tex] = constant
With further math you'll be able to solve for that constant as phi, the golden ratio. You can set up a quadratic equation, solve for it, and get phi.
Starter:
[tex]a_{n+1} = a_n + a_{n-1}[/tex] divide both sides by a_n
[tex]\frac{ a_{n+1} }{a_n} = 1 + \frac{ a_{n-1} }{a_n} }[/tex]
Take the limit as n goes to infinity, define
[tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n} = x[/tex], and go.
BoTemp, I am not so good in english. What I'm trying to prove is that the sequence of the terms a_n/a_(n-1), ... is convergent to a value, not the sum of these ratios (not series, like 1 + 1/2 + 1/3 + ...).
I know the formulas to find the golden ratio (1 + 5^1/2)/2, I would like to know if that proof is correct, if I could conclude that there is a limit or not.
thanks
"My goal is to prove that when n --> , a_n/a_(n-1) = a_(n+1)/a_n in the limit"
That's simply adjusting the indices. Let j= n-1. Then an-1= aj and an= aj+1. The sequence an/an-1 is exactly the same as aj+1/aj which is, in turn, exactly the same as an+1/an just labled differently. In the limit as n goes to infinity, j also goes to infinity and the two sequences have the same limit.
a_n/a_(n-1) [tex]\neq[/tex] a_(n+1)/a_n for all n that you can test by yourself, is quite different to say
[tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n}[/tex] = [tex]\frac{a_n}{a_{n-1}}[/tex]
I may be misunderstanding, but the limit value cannot include subscripts "n" or "n-1."
what you mean EnumaElish?
In your statement
[tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n} = \frac{a_n}{a_{n-1}}[/tex]
the right-hand side cannot have a_n or a_{n-1}. The limit must be independent of n.
Did you mean [itex]\lim_{n \rightarrow \infty} \left({a_{n+1}}\left/{a_n}\right.\right) = \lim_{n \rightarrow \infty} \left({a_n}\left/{a_{n-1}}\right.\right)[/itex]? [1]
If so, [1] does not prove convergence because it presumes that a limit exists in the first place. If there is no limit then [1] has no meaning.
I meant [1] as you said, sorry my mistake.
I see what you mean, my dificult is:
if [1] does not prove the convergence, why the procedure below do?
[tex]\frac{ a_{n+1} }{a_n} = 1 + \frac{ a_{n-1} }{a_n} }[/tex] ==>
==> phi = 1 + 1/phi ==> phi = (1 + 5^1/2)/2
Here I'm suposing that there is a limit like the other solution, right?
Thanks for your help!
Since a(n) > 0 for all n > 0 and a(n+1) = a(n) + a(n-1), {a(n)} is an increasing sequence for all n > 1.
Let r(n+1) = a(n+1)/a(n), then r(n+1) > 1 for all n > 1.
Suppose lim r(n) = infinity. Then lim 1/r(n) = 0. But since lim r(n+1) = 1 + lim 1/r(n), this implies infinity = 1, a contradiction. Therefore I can conclude that lim r(n) = L < infinity.
Then you can solve L = 1 + 1/L.
"Therefore I can conclude that lim r(n) = L < infinity."
as 0 < a(n-1)/a_n < 1 ==> 1 < a(n-1)/a_n + 1 < 2 ==> 1 < a(n+1)/a_n < 2
and if the values oscillate between 1 and 2? you prove that the limit do not diverges to infinity, but this not implies that there is a limit, am I right?
f(x) = sen(x), lim sen(x) is not infinite when x --> infinity, but there is no limit, the function oscillate between -1 and 1
Yes, you are right; which makes it clear that one cannot presume a limit exists.
I see, you're right...
We could prove convergence starting with this fact: 1 < a(n+1)/a_n < 2 , showing (I presume) that the sequence is bounded
to prove that it is monotonic, we should work with [tex]\frac{a_n}{a_n_-_1}[/tex] = [tex]\frac{a_n_+_1}{a_n}[/tex][tex]\pm[/tex] [tex]\frac{1}{a_n*a_n_-_1}[/tex]
for n even [tex]\frac{a_n}{a_n_-_1}[/tex] = [tex]\frac{a_n_+_1}{a_n}[/tex] - [tex]\frac{1}{a_n*a_n_-_1}[/tex]
for n odd [tex]\frac{a_n}{a_n_-_1}[/tex] = [tex]\frac{a_n_+_1}{a_n}[/tex] + [tex]\frac{1}{a_n*a_n_-_1}[/tex]
a_n < a_(n+1) < a_(n+2) < a_(n+3) < ... ==> [tex]\frac{1}{a_n*a_n_-_1}[/tex] --> 0 ==> the sequence [tex]\frac{a_n}{a_n_-_1}[/tex] increase in monotonic fashion, bounded above for n odd and decrease in monotonic fashion, bounded below for n even
  • · Replies 19 ·
  • · Replies 20 ·
