Bullet and pendulum bob initial speed help momentum.
The problem involves a bullet and a pendulum bob, focusing on the initial speed of the bullet after it embeds into the bob. The scenario includes a bullet of mass 7.0 g and a pendulum bob of mass 3.5 kg, which rises a vertical distance of 8.0 cm after the collision.
  • Participants discuss different equations for calculating the velocity of the pendulum and bullet system, with one participant suggesting a formula that incorporates mass, while others question the validity of including mass in that context.
The discussion is ongoing, with participants exploring the relationship between the variables involved and questioning the application of conservation of momentum. There is no clear consensus on the correct approach, as some participants are examining the role of mass in the calculations.
Participants note discrepancies with the results obtained from their calculations compared to the expected answers from the homework platform, indicating potential misunderstandings of the equations involved.
lettertwelve
bullet and pendulum bob...initial speed...help! momentum.
An 7.0 g bullet is fired into a 3.5 kg pendulum bob initially at rest and becomes embedded in it. If the pendulum rises a vertical distance of 8.0 cm, calculate the initial speed of the bullet.
________m/s
well there's many ways to do it, but here's one way:
v=sqrt((1+M/m)*2gh)
i tried it another way too, and got the same answer that i did with the above equation
so first, 7g bullet = .007kg bullet and height of 8cm = .08m
ok so then v=sqrt((1+3.5/.007)*2*9.8*.08) = ~28.03 m/s
now, i tried this TWO WAYS and got the same answer.
but webassign says it's wrong.
why?
The velocity of the pendulum and the bullet is given by:
[tex]v=\sqrt{2gh}[/tex]
The mass shouldn't enter into that part. Once v is known one can use the conservation of momentum to find the bullets initial speed.
EDIT: I see what you've done to include the mass. The problem is the mass part should be outside the square root.
which mass are you talking about?
The (1+M/m) term.
