Matrix Mechanics Homework: Calculate [p,x] = i h-bar
  • Thread starter Thread starter ehrenfest
    Matrix Mechanics
The discussion revolves around calculating the commutator [p,x] for the simple harmonic oscillator potential, specifically aiming to show that [p,x] = i h-bar using matrix representations of the position and momentum operators.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the expressions for the momentum and position operators in matrix form and explore the implications of these definitions on the commutation relation. Questions arise regarding the inclusion of creation and annihilation operators and the nature of the quantities being calculated (expectation values vs. operator commutators).
Participants are actively engaging with the problem, checking calculations, and clarifying concepts. Some have provided insights into the structure of the calculations, while others are questioning the assumptions and definitions being used. There is a recognition of the need to clarify the specific calculations being performed.
There is mention of the expectation values and their relationship to the operators, as well as the potential confusion between different representations of the operators. Participants are also considering the implications of Kronecker deltas in their calculations.
ehrenfest
My book says that we can express
[tex]p_{nm} = -i \sqrt{M \omega \hbar} \left( \delta_{n,m-1}\sqrt{m} - \delta_{n,m+1} \sqrt{m+1}\right)[/tex]
and
[tex]x_{nm} = \sqrt{\hbar/2M\omega} \left( \delta_{n,m-1} \sqrt{m} +\delta_{n,m+1}\sqrt{m+1}\right)[/tex]
for the simple harmonic oscillator potential.
I want to calculate [p,x] = i h-bar.
What I am saying is that when I calculate
[tex]\sum_{k}x_{nk}p_{km} - \sum_{k}p_{nk}x_{km}[/tex]
I get 0. Can someone check that? If I need to I can post more work.
and
Shouldn't there be some creation and annihilation operators in here? Usually they're written as "a" with or without a little dagger.
No, I think you are thinking of something else. x_nm is defined as <x_n|x|x_m> for example. |x_n> is nth eigenstate of the SHO Hamiltonian.
Ah, right. I remember them now.
These are not the x and p operators, they are expectation values. [p,x] = i h-bar is for the operators. The expectation values are just numbers, and the commutator of two numbers is always zero.
I am saying that [tex]\sum_{k}x_{nk}p_{km} - \sum_{k}p_{nk}x_{km}[/tex] is equal to 0 for each n and each m. So the entire matrix is equal to zero.
The problem in my book says, "show that [x,p] = ihbar holds as a matrix equation."
What do you get for
[tex]\sum_{k}x_{nk}p_{km}[/tex]?
[tex](1/2)i\hbar\delta_{n,m}[/tex]
and I get the same for the
[tex]\sum_{k}p_{nk}x_{km}[/tex]
All would be well if I got [tex]\sum_{k}p_{nk}x_{km}[/tex] equal to minus that, but I checked my algebra several times and I just don't know what is going on.
[p,x] = i h-bar
Just insert what p and x are in the linear combination of annihilation and creation operators, and use their commuting algeras.
OK, I'm over my denseness now. You're calculating [tex]<x_n|[p,x]|x_m>[/tex], right?
So, for [tex]\sum_{k}p_{nk}x_{km}[/tex] you should get that the [tex]\delta_{n,m}[/tex] terms actually cancel and the remaining terms have [tex]\delta_{n+2,m}[/tex] and [tex]\delta_{n-2,m}[/tex], and that for [tex]\sum_{k}x_{nk}p_{km}[/tex] you get those same terms, minus the final (correct) answer, proportional to [tex]\delta_{n,m}[/tex] of course. Can you show some work?
ehrenfest : can you please tell us exacly what you want to calculate?
Malawi, I think it's pretty clear what he is calculating. He has the matrix elements of p and x and wants to calculate the commutator using the matrix representation of those oeprators.
Ok, 2Tesla also asked. If this is a exercise in dealing with the matrix representation, or if he just wants [p,x]
Using the template is good. Saying exactly what the problem are. Now one can inteprent his problem to be:
I want to calculate [p,x] = i h-bar for the simple harmonic oscillator potential.
I see where I messed up. I just totally botched the replacement of n and m's with k's using the Kronecker deltas. Thanks.
  • · Replies 31 ·
