Finding Integer Solutions for y^2 = x^3 + n
  • Context: Undergrad
  • Thread starter Thread starter quila
    Integer
The discussion revolves around finding integer solutions for the equation y2 = x3 + n, where n is an integer. Participants explore various cases, including specific values of n and the implications of larger n, while considering the mathematical challenges involved in finding such solutions.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant questions how to find integer solutions for the equation and whether it is easier to determine the number of solutions.
  • Another participant references a classic Fermat's problem related to specific values of n (n = ±2) and discusses the implications of these cases.
  • Concerns are raised about the situation when n is large (n > 100) and the challenges that arise in finding solutions.
  • Multiple participants discuss the well-known problem of X2 = Y3 + 1, noting trivial solutions and exploring the conditions under which non-trivial solutions exist.
  • Some participants propose that there are infinite integers n such that n = x2 - y3, while others challenge this assertion by providing specific examples where no solutions exist.
  • There is a discussion about the implications of assuming both X and Y are even or odd, and how this affects the possibility of finding integer solutions.
  • Participants engage in a technical debate regarding the conditions under which x - 2 and x + 2 can be expressed as cubes, with some arguing that no cubes exist that are 4 apart.
  • The role of prime factors in the context of the equation is also examined, with references to the fundamental theorem of arithmetic.
Participants express differing views on the existence of integer solutions for various values of n, with some asserting that solutions exist for every integer n while others provide counterexamples. The discussion remains unresolved regarding the general case of finding integer solutions.
Limitations include the lack of consensus on the existence of solutions for all integers n and the dependence on specific cases discussed. The mathematical reasoning involves complex relationships between the variables that are not fully resolved.
quila
how does one go about finding integer solutions for an equation such as this? Is it easier to merely find how many solutions?
y^2 = x^3 + n, n is some integer.
if n = +- 2 this is a classic Fermat's problem: prove that 26 is the only natural number between an square and a cube (5^2 = 25 and 3^3 = 27)
what if n is large? say n>100
where did you find this problem? Could you put here with the exacly words?
I thought X^2=Y^3 + 1 was a well-known problem.
There are trivial solutions, such as y=0, x=1, or x=0, y=-1. Ingnoring that, we have (X-1)(X+1) = y^3, with all factors assumed positive. X-1 and X+1 can only have 2 as a common factor. And, in that case, one term is divisible by 4. X-1=2a^3, X+1 = 4b^3, assuming a>0, b>0, this gives us 2=4a^3-2b^3, or 1 =2a^3-b^3. This is only possible if a=b=1. Thus the solution is 3^2=2^3+1.
For negative terms,b=-1, a=-1, 1=b^3-2a^3, giving x-1=4a^3=-4, x+1=2b^3=-2, we could have found, but excluded: (-3)^2= 2^3+1 for a=b=-1.
If they have nothing in common we get 2 = b^3-a^3, which gives no answer in positive integers. However, X-1= a^3=-1, X+1= b^3=1, gives X=0, Y=-1, another trivial result.
Thus there is only one non-trivial solution, already given: 3^2= 2^3+1.
That is the solution where n = 1, but more importantly what the poster asks is what method can be used to obtain the solution if n = other, e.g. 22. One could pose an infinite number of such questions but I doubt that there is a direct methof of solution. At least there is no discussion of such a problem as far as I know.
there are infinite n such that n = x^2 - y^3, this is trivial
there are at least one x and one y such that n = x^2 - y^3 for every n integer? this is the question, I think... it's hard!
ramsey2879: At least there is no discussion of such a problem as far as I know.
I agree. I don't think anything has been done beyond piecemeal efforts. Obviously, n=1 is a simple case.
al-mahed: if n = +- 2 this is a classic Fermat's problem: prove that 26 is the only natural number between an square and a cube (5^2 = 25 and 3^3 = 27)
I have some memory of 3^3=5^2+2. I can't seem to find any information about these problems at all.
al-mahed: there are at least one x and one y such that n = x^2 - y^3 for every n integer? this is the question, I think... it's hard!
That, I feel is not true. Take 4=X^2-Y^3. Obviously Y=0 is such a solution, a negative Y impossible. But for X and Y greater than 0, consider them both even Then in this case we have 4=4x'^2+8y'^2. This leaves us 1=x'^2+2y'^3. Only solution y' = 0.
Now if X and Y are both odd,Y^3=(X-2)(X+2), assume X>2, these have no common factor, (since only 2 could be such a factor) x-2 =a^3, x+2 = b^3. This then gives
4 = b^3-a^3 = (b-a)(b^2+ab+a^2). Since a and b are odd, 4 divides b-a, and thus we have the form: [tex]1= (b^2+ab+a^2)\frac{b-a}{4}[/tex] Clearly b-a can not be zero and with only positive terms a^2+ab+b^2 exceeds 1.
I did not follow you here: Now if X and Y are both odd,Y^3=(X-2)(X+2), assume X>2, these have no common factor, (since only 2 could be such a factor) x-2 =a^3, x+2 = b^3.
why did you conclude that x-2 and x+2 can each be written as a cube?
He took n = 4, which means 4 = X^2-Y^3. Adding Y^3 - 4 to each side gives Y^3 = X^2 - 4 = (X - 2)(X + 2). Since they have no common factors, if one is not a cube then the product is not a cube.
There are no cubes which are 4 apart. The difference between consecutive cubes grows rapidly (quadratically).
Now I see, thanks!
I made my question because I had conclude that if only one is a cube the product can not be a cube, but is you right when you say: both need to be a cube, and if no one is a cube, there is no way an odd number N with the same factor than N + 4
Yes, this part is clear, I made another question, concerning the fact that y^3=(x-2)(x+2) ==> y| (x-2) or (x+2) only if y is prime (of course y dividing only one makes impossible the product be a cube). If y is not prime was not so clearly for me that (x-2)(x+2) cannot form a cube, although to be almost obvious.
What ever prime divides (x-2) and (x+2) also divides the sum, which is 4.
The fundamental theorem of arithmetic tells us that any integer can be decomposed into prime factors in only one way, without regard for order. Thus we only need to consider prime factors.
  • · Replies 25 ·
  • · Replies 33 ·
  • · Replies 17 ·
