What Are the Final Speeds of Billiard Balls After a Perfectly Elastic Collision?
  • Thread starter Thread starter VanKwisH
    Balls Collision
The discussion centers on calculating the final speeds of two billiard balls after a perfectly elastic collision. Given initial speeds of 2.0 m/s and 3.0 m/s in opposite directions, the final speeds are determined to be 3.0 m/s and 2.0 m/s, respectively. The conservation of momentum and kinetic energy equations are utilized, specifically m1v1 + m2v2 = m1v1' + m2v2' and 1/2 m1v1^2 + 1/2 m2v2^2 = 1/2 m1v1'^2 + 1/2 m2v2'^2. The solution involves algebraic manipulation to isolate the final velocities.
  • Understanding of conservation of momentum
  • Knowledge of kinetic energy equations
  • Basic algebraic manipulation skills
  • Familiarity with perfectly elastic collisions
  • Study the principles of conservation of momentum in collisions
  • Learn about kinetic energy conservation in elastic collisions
  • Practice solving problems involving two-body collisions
  • Explore advanced topics in collision theory, such as inelastic collisions
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators looking for examples of elastic collisions in real-world applications.
VanKwisH
Two Billiard balls of equal mass undergo a perfectly elastic head on collision
(Energy is conserved) . If the speed of one ball was initially at 2.0 m/s
and the other 3.0 m/s in the opposite direction, what will be their speeds after the
collision??
1/2 m1v1^2 + 1/2 m2mv2^2 = 1/2m1v1 '^2 + 1/2m2v2 '^2
so far i have simplified both formulas so that it's
v1' = v1 + v2 - v2'
v2' = v1^2 + v2^2 - v1 '^2
That's as far as a can go but I'm stuck what should my next step be...
The answer is v1 = 3 m/s & vs = 2 m/s if it helps anyone
Well, you've done the bulk work of the problem already. You have two unknowns (v1 and v2 final) in two separate expressions. Use your algebraic skillz to solve (i usually substitute when there's only 2 unknowns, but you can eliminate too).
  • · Replies 19 ·
  • · Replies 16 ·
