What is the problem with Log2?
  • Thread starter Thread starter asif zaidi
The discussion revolves around finding an approximate value for log(2) by using the upper sum method for the function f(x) = 1/x over the interval [1, 2]. The original poster expresses confusion regarding their calculations and the relationship between logarithms and integrals.
  • The original poster attempts to apply the definition of an integral to approximate log(2) but questions their result when comparing it to known values. They also explore the method's validity by applying it to a different function, f(x) = x^2.
Participants have provided clarifications regarding the notation of logarithms, particularly the distinction between common logarithm and natural logarithm. The original poster acknowledges this clarification and notes that their answer now matches expectations.
There is a discussion about the conventions of logarithmic notation in different educational contexts, which may affect the understanding of the problem. The original poster's confusion appears to stem from these conventions.
asif zaidi
Problem statement
Find an approximate value for log(2) by subdividing the interval [1,2] into sub-intervals of length 1/n and using this subdivision to compute the upper sum for the function f(x)=1/x. Compute the upper sum for n=1,2,...,10.
My solution
The way I approached this is as follows
Use the definition of integral: as n -> inf ([tex]\sum[/tex] f(ci)*partition length)
a. take a partition of size 0.1 (as I have 10 points from 1-2)
b. find f(1.0) + f(1.1) + ... f(1.9) = 1/1 + 1/1.1 + 1/1.2 + ... 1/1.9 = 7.185
c. Multiply 7.185*0.1 = 0.7185
Obviously log2 = 0.301 ~= 0.7185/2. <--- Error.
To see if my understanding of integrals is right, I used same method for f(x) =x^2 from [1,2] and came up with the right answer. So what am I doing wrong with 1/x.
Thanks
Asif
Because you hit the log button instead of the ln button on your calculator :-p
You've hit an unfortunate boundary in math notation! In "elementary" course (say introductory calculus and below) typically "log" is used for the common log (base 10) and "ln" is used for the natural logarithm. Most calculators use "log" for common logarithm and "ln" for natural logarithm. But in higher level courses common logarithm is never used and "log" is used for the natural logarithm.
The function you get by integrating 1/x is the natural logarithm.
OK - thanks to both.
That explains it and my answer matches.
Well, in my school, we are taught that 'ln' is natural logarithm, 'lg' is decimal logarithm (base 10) and 'log' is logarithm with any other base.
