What Determines a Solenoid's Magnetic Field: Voltage or Power?
The discussion revolves around the factors that determine a solenoid's magnetic field, specifically questioning whether voltage or power plays a more significant role. Participants explore theoretical aspects, conservation of energy, and the implications of superconductivity in relation to magnetic fields.
  • One participant suggests that voltage and power are not the primary determinants of a solenoid's magnetic field, emphasizing the role of current instead.
  • Another participant introduces the concept of superconductivity, arguing that a superconducting loop can generate a strong magnetic field without voltage or power.
  • There is a discussion about the conservation of energy, with one participant stating that the energy supplied to the circuit is either used to increase the magnetic field or is lost as heat due to resistance.
  • Questions arise regarding the definitions of current and magnetic field, with participants seeking clarity on whether they refer to strength or extent.
  • One participant notes that the energy lost by resistance is given by the formula Current^2 * Resistance and questions the source of power in AC or DC systems.
  • Another participant emphasizes that the context of energy discussions may not be appropriate for motors, suggesting a need for clarity in the questions posed.
  • There is a query about maximizing the torque constant of a motor and whether there is a theoretical limit to it, with references to external resources for further exploration.
Participants express differing views on the roles of voltage, power, and current in generating a magnetic field, with no consensus reached on the primary factor. The discussion remains unresolved regarding the implications for motors and the context in which the magnetic fields are being considered.
Participants highlight the need for clarity in definitions and context, particularly when discussing motors versus static magnetic fields. There are unresolved questions about the source of power in different circuit configurations and the theoretical limits of torque constants.
kmarinas86
So what produces a solenoid's magnetic field? Voltage or Power?
Voltage = Current * Resistance
Power = Current^2 * Resistance
Magnetic field magnitude of a solenoid = magnetic constant * turns * current
We can quadruple the turns using the four times of the same type of wire, but that will quadruple the resistance. We can then double the voltage, but that will still leave us with half the current. Power here doesn't change. However turns quadrupled and current is half. More magnetic field?
Alternatively, with the same voltage, we can double the turns using the same type of wire, but that will double the resistance and give us half the current. Voltage would remain the same, and the ampere-turns would remain the same! The power does not!
So why do they say that power is needed to produce a magnetic field? Why isn't it voltage that produces the magnetic field?
Neither. Consider a superconducting loop, it has neither voltage nor power but can have a very strong magnetic field. Fundamentally, it is the current that produces a magnetic field.
The simplest way to approach this is through conservation of energy. The magnetic field stores energy, any resistance dissapates energy. The energy supplied to the circuit must go either to increasing the magnetic field or to heating the resistance, so the magnetic field energy is the difference between the energy supplied and the energy lost by resistance. In the steady-state, when the magnetic field and the current are not changing, ALL of the power goes into the resistance.
edit: typo
When you say "current" do you mean amps, or do you mean amps driven over a distance? When you say "magnetic field" do you mean the strength of the magnetic field, or do you mean the extent of the magnetic field?
The energy lost by resistance is Current^2 * Resistance. So where does the rest of the power come from in AC, or say, in a DC system where the circuit is repeatedly connected and disconnected? How do I maximize the torque constant of the motor?
kmarinas86 said:
When you say "current" do you mean amps per second, or do you mean amps per second driven over a distance? When you say "magnetic field" do you mean the strength of the magnetic field, or do you mean the extent of the magnetic field?
Current is just Amps, not Amps/second. But you are right, the longer distance your current covers the greater the magnetic field.
When I say "magnetic field" in the context of energy conservation I mean both the strength and the spatial extent. A higher magnetic field stores a greater amount of energy per unit volume of space. Try this link for a start http://hyperphysics.phy-astr.gsu.edu/hbase/electric/engfie.html As you can see, you can store the same amount of energy as a large and weak magnetic field or as a small and strong magnetic field.
I'm not sure I understand your question. The power always comes from the power source, e.g. the chemical reaction in the battery, the mechanical work done on the turbine blades, etc. Wether it is AC or DC is irrelevant.
Also, my comments about energy are really not appropriate for the context of a motor, they are about a coil in space just setting up a magnetic field in free space and not for a magnetic field that is doing work on something. If you are asking about motors could you please re-state your question in the proper context.
How is the torque constant maximized? Is there a theoretical limit to it?
  • · Replies 42 ·
