| Thread Closed |
Inverse Laplace Transform - Step Function? |
Share Thread | Thread Tools |
| Dec16-07, 11:46 PM | #1 |
Given...
(2s[tex]^{2}[/tex]+1)e[tex]^{-s}[/tex] ------------------ (s - 1)(s[tex]^{2}[/tex] + 4s + 5) Find the inverse Laplace Transform. I am unsure where to start and am just looking for a little direction, not an answer. From past experience, I am assuming I will have to rewrite this in another form...perhaps by taking out the e[tex]^{-s}[/tex] term. I also believe I will need to complete the square on the quadratic in the denominator. If someone could just point me in the right direction, that would be greatly appreciated! Thanks!!! |
| Dec17-07, 12:10 AM | #2 |
Recognitions:
First, use the properties of the Laplace transform to get rid of the [itex]e^{-s}[/itex]. Then use partial fractions to do the rest.
| Dec17-07, 12:30 AM | #3 |
Ok, so I did that...here's my work...(note, I factored out the 1/10 that appears in both terms).
(e[tex]^{-s}[/tex]/10)[tex]\frac{17s+5}{(s+2)^{2}+4s+5}[/tex]+[tex]\frac{3}{s-1}[/tex] Then I completed the square on the quadratic in the denominator and rewrote it... (e[tex]^{-s}[/tex]/10)[tex]\frac{17s+5}{(s+2)^{2}+1}[/tex]+[tex]\frac{3}{s-1}[/tex] Now, finding the inverse Laplace Transform of 3/(s-1) is very simple. So is finding the inverse transform of e[tex]^{-s}[/tex]. But the term containing the 17s + 5 is confusing me. |
| Dec17-07, 12:32 AM | #4 |
Recognitions:
Try writing
[tex]\frac{17s}{(s+2)^2+1} + \frac{5}{(s+2)^2+1}[/tex] Also, your formulas will be easier to read if you write the entire thing in TeX instead of just bits and pieces. |
| Dec17-07, 12:37 AM | #5 |
Recognitions:
And you should be able to get rid of the [itex]e^{-s}[/itex] part by using this property:
[tex]\mathcal{L}\{f(t-a)\} = e^{-as}F(s)[/tex] |
| Dec17-07, 12:39 AM | #6 |
Thanks very much! This is only my second time using TeX so I apologize for that. Getting used to it.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Inverse Laplace Transform - Step Function?
| Inverse Laplace Transform Involving a Step (Heaviside) Function | Differential Equations | 1 | ||
| Laplace Transform - Step Function | Calculus & Beyond Homework | 1 | ||
| Finding an inverse Laplace Transform for a function - solving IVPs with Laplace | Calculus & Beyond Homework | 2 | ||
