Convergence of light rays and Optical Path Length (OPL)
The discussion revolves around the convergence of light rays and the concept of Optical Path Length (OPL), particularly in the context of rays originating from a distant source and converging at a point. Participants explore the conditions under which these rays may or may not travel the same OPL, considering both theoretical and practical implications.
  • One participant asserts that all rays from a distant source converging at a point need to travel the same OPL.
  • Another participant counters that this requirement depends on the intended use of the rays at the convergence point.
  • A different participant suggests that rays from a planar source do not typically travel the same OPL.
  • One participant provides a mathematical estimation of the maximum difference in OPL for rays from a planar object, indicating that while the difference can be small compared to the distance to the convergence point, it can be significant relative to the wavelength of light.
  • A question is raised about the scenario where rays originate from the same point source, implying a potential difference in OPL under those conditions.
Participants do not appear to reach a consensus, as there are multiple competing views regarding whether rays converging at a point must travel the same OPL and under what conditions this may or may not hold true.
There are limitations regarding the assumptions made about the source of the rays and the geometrical configurations involved, as well as the dependence on definitions of OPL and the specific conditions of convergence.
pardesi
Why do all rays coming from far off distance from a source(may be planar)... converging at a point need to travel the same Optical Path Length(OPL)
Science news on Phys.org
They don't have to - it depends on what you want to do with them at the point.
Usually they don't travel the same OPL.
For a truly planar object with its plane is normal to the direction of the rays, then you can estimate the maximum difference in the OPL from its largest dimension (say 2d) and the distance to the point of convergence (call this D):
[tex]\delta L= D[(1+(d/D)^2)^{1/2}-1] \approx d^2/2D[/tex]
This number is tiny compared to D, but it's much harder to make it small compared to the wavelength of the light.
but is it true if they start from the same point source
  • · Replies 22 ·
  • · Replies 17 ·
