Calculate Recoil Velocity: 4.85kg Stone & 102kg Canoe
  • Thread starter Thread starter Jacque77
    Velocity
The discussion focuses on calculating the horizontal recoil velocity of a stationary canoe when a person throws a 4.85 kg stone at a velocity of +7.73 m/s at an angle of 35.3 degrees. The combined mass of the person and canoe is 102 kg. The correct calculation involves determining the horizontal component of the stone's velocity using the cosine function, resulting in a horizontal velocity of 6.3087 m/s. The recoil velocity is then calculated using the conservation of momentum, yielding a recoil velocity of -0.28327 m/s, indicating movement in the opposite direction.
  • Understanding of Newton's laws of motion
  • Basic trigonometry, specifically cosine function
  • Familiarity with the concept of conservation of momentum
  • Ability to perform calculations involving mass and velocity
  • Review the principles of conservation of momentum in one-dimensional systems
  • Learn about vector decomposition in physics
  • Explore the effects of angles on projectile motion
  • Practice similar problems involving recoil and momentum calculations
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators seeking to clarify concepts related to projectile motion and recoil effects.
Jacque77
First: My course has sig figs disabled. We are recording all that is shown in calculations. Its my instructor's choice, not mine. Please do not lecture on sig figs. I know already. ;)
Problem:
A person stands in a stationary canoe and throws a 4.85-kg stone with a velocity of +7.73 m/s at an angle of 35.3 ° above the horizontal. The person and canoe have a combined mass of 102 kg. Ignore air resistance and effects of the water and find the horizontal recoil velocity (magnitude and direction) of the person and canoe.
horizontal velocity = velocity of 7.73m/s * cos 35.3 = 6.3087
mass of stone 4.58kg * horizontal velocity of 6.3087 = 28.894 kg m/s
28.894 kg m/s = 102kg * recoil velocity
28.894 / 102 = recoil velocity = -0.28327 m/s This is incorrect. What have I done wrong? The negative is for the opposite direction movement.
Do you know the answer? Also, check the exact wording of the problem once more, in case something has been missed.
Presumably, either 4.85 kg. or 4.58 kg. is correct for the mass of the stone. (I also want to stay away from someone who can throw an 11 pound stone that fast...). Somewhere you have a copying error, which may explain why the computer didn't like your answer...
