How Does Friction Affect the Motion of Three Blocks?
  • Thread starter Thread starter complexc25
    Blocks Friction
The discussion revolves around a physics problem involving three blocks and the effects of friction on their motion. The problem specifically addresses the relationship between the masses, tensions, and frictional forces in a system where one block is affected by kinetic friction on a table.
  • Participants discuss the equations of motion for each block, particularly focusing on the application of Newton's second law. There are attempts to set up equations for the tensions and forces acting on the blocks, with some questioning the assumptions made about the tensions being equal.
The discussion is ongoing, with participants providing hints and guidance on how to approach the problem. There is recognition of the need to derive separate equations for each mass and to consider the differences in tension for the blocks. Multiple interpretations of the problem setup are being explored.
Participants are working under the constraints of the given coefficients of friction and the masses involved. There is an emphasis on ensuring the correct application of physical laws without providing direct solutions.
complexc25
You are given that the coefficient of kinetic friction between the block and the table in the figure is 0.560, and m1 = 0.150 kg and m2 = 0.250 kg.
(a) What should m3 be if the system is to move with a constant speed?
this is what i have:
T2 - T1 - f = m3a
m2g - m1g - ukg = m3
2.45 - 9.65 - 5.488 = 4.508kg
the answer is wrong, what is it that i am doing wrong?
T2 - T1 - f = m3a
This is good.
This is not good. For one thing, the tensions are not equal to the weights.
Hint: Apply Newton's 2nd law to each mass separately. You took care of M3, now come up with equations for M1 & M2.
You'll combine all three equations to solve for the acceleration and the tensions.
i don't understand, i have for:
m1
T - m1g = m1a
m2
m2g - T = m2a
m1
T - m1g = m1a
m2
m2g - T = m2a
Looks good, except that the tensions are different. Use T1 for m1 and T2 for m2.
  • · Replies 17 ·
