How to Find the Limit of (tanx)^cosx as x Approaches Infinity?
The problem involves finding the limit of (tanx)^cosx as x approaches infinity, specifically exploring the behavior of the functions involved as x increases without bound.
  • Participants discuss the application of L'Hopital's rule and the need to rearrange the expression to fit an appropriate form. There is uncertainty regarding the limits of cosx and the conditions under which L'Hopital's rule can be applied.
The discussion is ongoing, with participants questioning the validity of using L'Hopital's rule for the given limit and exploring the necessary conditions for its application. Some participants express confusion about the limits of the functions involved.
There is a mention of specific directions that require rearranging the problem to use L'Hopital's rule, indicating that the participants are working within a structured homework framework.
fk378
Find the limit of (tanx)^cosx as x-->infinity
Rearrange the equation so that you can use L'Hopital's rule for the form of (infinity/infinity)
I did ln(tanx)^cosx = cosxlntanx
I know the limit of tanx as x-->infinity is pi/2
the limit of cosx as x-->infinity is infinity
Now, I don't know where to go from here
"the limit of cosx as x-->infinity is 1 (or is it infinity?)"
That limit doesn't exist.
Oh okay. So now I have infinity x infinity. I can use L'Hopital's rule but I don't know how to set up the function.
No, you cannot use L'Hopital's rule for that. "Infinity* infinity" is not one of cases for which you can use L'Hopital's rule- nor do you need to. You have already been told the answer.
I just noticed in the directions it says to rearrange the problem so that you can use L'Hopital's rule.
Well then, what are the special cases in which L'Hopital's Rule can be applied? That is what are indeterminate forms?
Casey
  • · Replies 23 ·
  • · Replies 20 ·
