Time dilation and the photon clock
The discussion revolves around the concept of time dilation as illustrated by the example of a photon clock compared to a hypothetical tennis ball clock. Participants explore the implications of relative motion on the ticking of these clocks and question how the example demonstrates time dilation specifically, rather than just the effects of movement on clock mechanisms.
  • One participant questions how the photon clock example demonstrates time dilation, suggesting that a tennis ball clock would show similar effects without invoking time dilation.
  • Another participant emphasizes the second postulate of relativity, noting that the speed of light is constant in all inertial frames, unlike the speed of a tennis ball.
  • Some participants argue that all moving clocks, regardless of their mechanism, will exhibit the same time dilation effect due to relative motion.
  • There is a discussion about the complexities of analyzing a tennis ball clock compared to a photon clock, with some asserting that the latter is easier to analyze for time dilation.
  • One participant suggests that the observed differences in ticking rates are due to the design of the clock rather than actual time dilation.
  • Another participant points out that if the tennis ball's speed were constant, it would not be the same in all frames, which complicates the comparison with the photon clock.
Participants express differing views on whether the example of the photon clock effectively demonstrates time dilation. Some maintain that it does, while others argue that the differences in ticking rates are due to the mechanics of the clocks rather than time dilation itself. The discussion remains unresolved with multiple competing perspectives.
There are limitations in the assumptions made regarding the behavior of the tennis ball clock, particularly concerning its speed in different frames of reference. The discussion also highlights the complexity of analyzing non-light-speed clocks in the context of relativity.
Stellar1
Hello,
I just baught my next set of textbooks and started reading about relativity. In one of the books it uses the example of a two clocks who "tick" every time a photon it emitted hits the mirror and returns to the sensor. It demonstrated that, if the box containing this clock is moving, it will tick slower than one that is stationary. I understand this and why, but I don't understand how this is supposed to show time dilation? If I perform the same experiment but with a clock that shoots a tennis ball, while fixing the tennis ball's speed at a constant value, the moving clock, even at speeds far below the speed of light, will still tick slower than the stationary one, yet there would not really be time dilation.
The second postulate of relativity is that the speed of light (i.e. the speed of a photon) is the same in all inertial (non-acclerated) frames of reference. There is no equivalent postulate for tennis balls :)
Of course, the speed of a photon isn't constant :P It's just constant in a vacuum, and that is given as c
Yes, I know its not constant everywhere, but that's what I meant, in a vacuum.
Never the less, I still do not see how this test actually displays any time dilation.
jcsd: if the tennis ball were held at a constant speed, the speed of the tenis ball would also be the same in all inertial frames of reference.
Can anyone simply explain to me how this whole example shows time dilation, rather than the mechanism of the clock simply being affected by the movement? That's all I see happening, the mechanism of the clock is made such that the clock is only accurate when it is stationary.
Why do you say that the moving tennis-ball clock will tick slower than a stationary tennis-ball clock even at speeds far below light speed?
And why do you think that with a tennis-ball clock there "would not really be time dilation"?
All moving clocks will be observed to slow down by the same factor, whether made of light beams, tennis balls, or the ticking of a human heart. Of course, analyzing the tennis-ball clock from first principles would be much harder since--as jcsd stated--there's no simple principle about the speed of a tennis ball being the same in all frames.
Yes, simply put in relativity all motion is relative (whence relativity). There is no absolute way to distinguish between a stationery and a moving observer (assuming both observers are inertial). Someone who was moving with the 'moving' photon clock would view the same time dialtion effect on a 'stationery' photon clock.
The speed of a tennis ball (unless they are traveling at c, which it is safe to assume they are not unless otherwise stated), cannot be the same in all inertial frames of reference.
Because if the speed of the tennis ball is constant, then the stationary clock's tennis ball has only a vertical component for velocity. The moving clock has both a vertical and horizontal component for it's tennis ball's velocity, and the speed can not exceed that of the stationary one's vertical velocity therefore the moving clock's tennis ball's vertical velocity is slower than that of the stationary one, thus the clock ticks slower.
Because it is moving at speeds far below that of the speed of light, yet the ticks can still differ greatly. The clocks will be far out of sync, but it isn't due to time dilation, it is due to the way the clocks were constructed.
Not at all, not if the tennis ball's speed is maintained at a constant and equal level between the two clocks. One clock's tennis ball will have a faster vertical velocity than the other, therefore the one that's moving will tick slower.
Ok, but how does this whole example prove time dilation? It simply shows the inexactitude of the mechanism of the clock, does it not?
If it was constant, then why not?
Ah, I see what you were doing. You were assuming that the tennis ball speed would be constant in all frames (like for photons), which is not true. (Only things that move at lightspeed can have the same speed in all frames.)
An ordinary tennis ball clock (if there's such a thing) would behave like any other clock. All clocks exhibit the same "slowing down" affect due to relative motion. It has to be this way, otherwise the laws of physics would depend on one's arbitrary speed, which they do not.
The reason why the light clock is used as an example is that it is easy to analyze and deduce the time dilation factor. As I stated earlier, analyzing the behavior of the tennis ball clock to predict the time dilation factor would not be simple--but it could be done. (Since the tennis ball does not have the same speed in all frames, you would have to use the relativistic transformation for velocity to predict its speed in various frames.)
I know that's not true, but let's make that assumption. It doesn't change the laws of physics. If need be, let's say its not a tennis ball but a device that will exert the appropriate amount of thrust in the appropriate direction in order to maintain that constant speed.
I know it will. But I'm not asking about that, I'm asking about how the experiment/example itsself shows time dilation. I don't see that it does, I just see a flawed design of the clock.
But as I see it, it is not time dilation that is occurring... time still goes by at the same rate, its just the clock that records things differently depending on how fast the clock is travelling.
But if we use a tennis ball, the time dilation, according to the clocks, will be much greater than according to the photon clocks.
In order for that to work, the thrust would only be exerted as seen in one frame, and that would involve a change in the law of Physics between the two frames.
We are talking about a difference between identical clocks.
Imagine that you have a "tennis ball" clock running next to each photon clock. An observer next to each set of clocks notes that the photon clock ticks x times for every one tick of the tennis ball clock next to it. This must be true for any observer watching the pair of clocks. Thus if the photon is seen as ticking twice as slow due tot he fact that the motion of the clock, the tennis ball clock must also tick half as slow in order to maintain that x to 1 ratio. The tennis ball clock and the photon undergo the same time dilation.
How would it involve a change in the law of physics? In any case, it is irrelevant because I was just using it as an example to better convey my question "how do we know that it is time dilation that occurs rather than inaccuracy in the equipment?"
Indeed they are identical; however, the accuracy of it is dependent on the speed of the clock. It seems to me that, rather than time dilation occurring in the example, it is simply inaccuracy in the equipment that's responsible for time being different.
Indeed, I understand that. My point is, however, that the time dilation measured by the difference of the clock's values for the tennisball is different than that of the photon clock...
Instead of concentrating only on the second postulate, you should remember the first.
That means that it does not matter whether the clock is moving and the observer is stationary, or the clock is stationary and the observer is moving.
This implies that the photon in a stationary clock is moving at the same speed as seen by every observer moving at arbitrary speed relative to the clock. How you achieve that with thrusters?
Unfortunately that does require a change in the laws of physics. Unless the tennis balls are moving at light speed (not possible), they will have different speeds depending upon who's doing the observing. And there's no possible device that could ensure the same speed for all observers.
Why do you keep saying this? Time dilation measured by any kind of clock will be the same.
What orientation does the tennis ball clock have? That is, do the tennis balls travel parallel with the frame's velocity or transversely to that velocity.
This seems to make a difference.
Say we have two observers with a tennis ball clock each. One we consider to be stationary and the other we consider to be in motion. We set the clocks in motion when the observers are collocated. At the end of one tick and one tock, where are the tennis balls?
Doesn't it all rely on what we mean by set the "clocks in motion"? If we think that the operating speed of the tennis ball in each clock is vtb then setting the clocks in motion means bestowing enough momentum to each tennis ball such that it attains this speed. The amount of moment transferred may be lorentz invariant, but in the moving frame you have to overcome a little inertia as well as setting the tennis ball in motion (or possibly give the tennis ball insufficient momentum to account for the frame's motion, depending on the orientation of the clock, the effect is the same either way). The tennis ball in moving frame will move more slowly.
It doesn't seem valid to compare this to the operation of a light clock (where we don't actually need to provide the photon with momentum, we just release it).
That said, the light clock derivation has its own problems, specifically when you orient the clock such that the photon travels parallel with the frame's motion.
cheers,
neopolitan
As Ich has already pointed out, you are missing an important part of this whole scenerio.
It doesn't matter which photon clock is considered as "moving". You have two identical photon clocks, each with an observer at rest with repect to it. The photon clocks have a relative velocity to each other. Each observer notes that his clock ticks once every sec. Each observer will also note that the other clock will take longer than one sec between ticks. IOW, the two observers do not measure the same amount of time as elapsing between two given events (such as the ticking of one particular clock).
Nonsense. When the light clock is oriented parallel to the direction of motion the derivation is a bit different, but it still works just fine.
Hmm, let me start this from scratch.
Forgetting about the whole tennis ball clock analogy, what is it about the photon-clock that proves time dilation? Maybe that's the fundamental point I'm missing.
Alright, one sec. I just lied down in bed for a while and just thought about the whole situation. So I see what you are saying now and what you mean by the tennis ball not being the same speed between the two inertial frames of reference.
So, what you are saying is that, since the speed of light is maxed at c, the stationary clock's photons are moving vertically at c. From the perspective of the moving clock, however, the photons of the stationary clock would also have a horizontal component for velocity, which would put their speed above c, which is impossible, therefore it is time that must slow down to maintain the speed at c, correct?
Stellar1 said:
...which would put their speed above c, which is impossible, therefore it is time that must slow down to maintain the speed at c, correct?
Bingo. That's the whole point.
IF we lived in a universe where tennis balls always moved at a specific speed in a vacuum AND if the speed they move was always the same for all inertial observers THEN the tennis ball clock would also demonstrate time dilation in exactly the same manner.
Since we don't live in a universe where tennis balls behave this way the tennis ball clock cannot demonstrate time dilation. It will, of course, slow down like any other mechanical clock when viewed from a different inertial frame but because tennis balls can have any velocity < c there's no way to calculate delta t using tennis balls.
So my next question is this, what experiments have shown that this is the case? In other words, how do we know that it is time dilation that occurs rather than speed of the photon relative to the moving clock being greater than c?
Okay you have two photon clocks, A and B. Each is uses light which bounces back a forth between two mirrors placed a tad under 150,000 km apart, such that if the two clocks were sitting right next to each other they would both tick at 1 sec intervals.
Now we add two observers, one by each clock and at rest with respect to it and put the clocks in motion with respect to each other along a line at a right angle to the photons of either clock as seen by that clocks observer.
According to each observer, he and his clock is at rest, and the other observer and their clock is in motion. Thus each observer measures his clock as ticking once every second.
When they measure the other clock's ticks however they note otherwise. In the time it takes for his clock to tick off on second, the other clock has moved some distance along its line of motion. The photons for that other clock must travel a diagonal path to bounce between the mirrors, and this diagonal path will be longer than the 150,000 km separation between the mirrors. Since the photons must travel at c according to our observer, it must take longer for the photons of the other clock to complete the round trip. For instance, if the relative velocity between the two clocks is 0.866c, then he will measure 2 ticks of his clock for every 1 tick of the other clock.
This is true whether is is is observer A looking at clock B or observer B is looking at clock A. Each will see the other clock as ticking slow. This is what time dilation is.
And each is equally justified in saying that his own clock is ticking at one sec per sec.
IOW, time is not an absolute measurement and there is no one true rate at which time can be said to pass.
Something like that. Here's how I would phrase it. In a frame in which the light clock is stationary, the photons move vertically the length of the clock. Since photons move at speed c, it takes them a certain amount of time to move across that distance. Now from a frame in which the light clock is moving sideways, the photons move through a greater distance (since they move horizontally as well as vertically). If they move through a greater distance it must take more time, since photons move at the same speed c in any frame. So if the clock is built such that one "tick" takes 1 second when it's stationary, that same tick will take longer than 1 second when viewed from a moving frame. That's how you can deduce that moving clocks run slow compared to stationary clocks.
Ok, so, what experiments have shown this to be the case, rather than the relative velocity beingg reater than c?
There are many experiments confirming time dilation. Check out http://en.wikipedia.org/wiki/Time_dilation#Experimental_confirmation" for some of them.
There is a bit of bootstrapping required. To the best of my knowledge, you can't use the light clock oriented parallel to the direction of motion to derive the equation for time dilation. The standard approach, the only one I have ever seen, is to do time dilation with a transverse orientation and then do spatial contraction with a parallel orientation and knowledge of time dilation.
I am willing to stand corrected if you can derive the equation for time dilation without assuming spatial contraction using nothing more than a light clock aligned parallel to the direction of motion. Note that I am not talking about bootstrapping, I am talking about first principles. No reference to Lorentz boosts, no reference to spatial contraction, no reference to anything that comes after you have established time dilation to derive time dilation. You can't use more advanced concepts to prove this simple one either, so no tensors, no geodesics.
I am willing to make an exception, if you can establish spatial contraction using nothing more than the light clock on the side, you can then use that to establish time dilation.
Anyone may take up the challenge. Just remember - first principles, no "well, I use 4-vector notation to describe Minkowski space, that's good enough for me".
cheers,
neopolitan
Special relativity has tons of experimental support.
One famous demonstration of time dilation itself was done with mu-mesons back in the 40s: http://www.egglescliffe.org.uk/physics/relativity/muons1_.html"
Here's another reference for experimental evidence: http://www2.corepower.com:8080/~relfaq/experiments.html"
For one thing, if the speed of light varied with relative motion, we would have measured such a variation.
Also, we have measured the effects of time dilation directly. A famous example is the Muon Experiment. Muons are subtomic particles that are created by cosmic ray hitting the upper atmosphere. The muons are created we a velocity of a good fraction of c. Muons also have a short half-life; they don't exist very long before they decay into other particles.
We know that the muons are created 40 miles up, we know how fast they are moving when they are created, and how long they should last. Given these facts, it can be calculated that very few muons created in the upper atmosphere should last long enough to reach the surface of the Earth. But many more muons are measured as reaching the Surface, the reason being that due to the fact that they are traveling so close to c, time dilation slow their aging and allows them to reach the surface before they decay.
So what would be your point? How does that invalidate the standard light clock demonstation of time dilation? Where's the "problem"?
The problem is that as an expounder of SR are, on one hand, saying any clock, irrespective of make, model, mode of operation or orientation, in an inertial frame which has a velocity relative to a "stationary" reference frame will run slower than an identical clock at rest in the reference frame. Then you go to prove it and say, we must have a specific orientation to prove this. This seems to be a problem. Perhaps it is a philosophic bagatelle, but it is one which you can dismiss if you can do the derivation that you said you do and I challenged you to produce.
Can you provide the derivation? You don't need to provide it immediately, it may take you some time.
cheers,
neopolitan
  • · Replies 58 ·
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 54 ·
  • · Replies 55 ·
  • · Replies 17 ·
  • · Replies 88 ·
