Indefinite Integration Problem
The discussion revolves around the indefinite integration of the function \(\int \frac{1}{\sin{x}+\cos{x}}dx\), focusing on various approaches to simplify and solve the integral using trigonometric identities and substitutions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore different methods for simplifying the integral, including multiplying by a conjugate, using trigonometric identities, and considering substitutions like \(t=\tan(x/2)\). Some participants question the correctness of signs in the expressions and the application of identities.
The discussion is active, with multiple participants providing insights and suggestions for different approaches. There is a mix of agreement and questioning regarding the methods proposed, indicating a collaborative exploration of the problem.
Participants express uncertainty about certain trigonometric identities and their applications, and there are mentions of homework constraints that may limit the exploration of certain methods.
ron_jay
Integrate: [tex]\int \frac{1}{\sin{x}+cos{x}}dx[/tex]
The one above and basic integration formulae which need not be mentioned.
[tex]\int \frac{1}{(\sin{x}+cos{x})} \times\frac{(\sin{x}-cos{x})}{(\sin{x}-cos{x})} dx[/tex]
[tex]- \int \frac{\sin{x}-cos{x}}{\cos^2{x}-sin^2{x}} dx[/tex]
[tex]- \int \frac{\sin{x}-cos{x}}{\cos{2x}} dx[/tex]
Well after that I can't figure out what to do next...
[tex]-\int \frac{\sin{x}-cos{x}}{\cos^2{x}-sin^2{x}} dx[/tex]
break up the numerator and then use trig identities to change the denominator so you have it in terms of only cosine and sine respectively.
i'm doing it right now, interesting.
argh ... hm
This is incorrect. There should be no negative sign in front of the integral.
he factored out a negative so he could change it to cos2x unless i forgot my algebra.
[tex]\sin^{2}x-\cos^{2}x \rightarrow -(\cos^{2}x-\sin^{2}x)[/tex]
Whao! My bad, didn't realize he'd swapped the cosine and sine.
How about using the identity sin(x)+cos(x)=sqrt(2)cos(x-pi/4), if you know the antiderivative of sec(x)?
Or the substitution t=tan(x/2)?
How about splitting this into two terms and substituting 2cos^2(x)-1 for the denominator in one case and 1-2sin^2(x) in the other? (Though morphisms first suggestion is much more direct).
Yes, that's what I meant. I didn't state it clearly so that the OP could work it. After doing that though, I didn't like the results.
It's not that bad. Then you just have to apply partial fractions to integrate 1/(2u^2-1). You can see the sqrt(2) popping up, which corresponds to stuff you would get in morphism's approach if you expand the trig functions and use stuff like sin(pi/4)=sqrt(2)/2.
K let me keep going further, I bet I'm having more fun with this Integral than ron_jay, lol.
This is an interesting proposition, however, I have not come across the given identity yet or the anti-derivative of sec(x). So either I do it in a different way or learn these new identities, the proof of which I would be glad if you could post a link to.
By splitting, is this what you mean:
[tex]\int \frac{\cos{x}}{1-2\sin^2{x}} - \frac{\sin{x}}{2\cos^2{x}-1} dx[/tex]
Where did you get this identity from? Just plug in x= 60 or any value and see if you get LHS=RHS
[tex]\int \frac{\cos{x}}{2\cos^2{x}-1} - \frac{\sin{x}}{1-2\sin^2{x}} dx[/tex]
you chose the wrong trig identities
if you switch around the denominators, do you notice that you can use u-substitutions?
from there, 1 will be nice to integrate while the other you will need to use partial fractions.
The identity is just cos(x-y)=sin(x)sin(y)+cos(x)cos(y) with y=pi/4 so that sin(y)=cos(y)=1/sqrt(2). [unplebeian: make sure you don't confuse radians with degrees.]
As for the antiderivative of sec(x), there are several ways of computing it - I count 3 off the top of my head. I will demonstrate how it can be done with the substitution t=tan(x/2), although it's not the slickest way to go about it.
First we need the following preliminary result:
cos(x) = cos^2(x/2) - sin^2(x/2) = (1 - tan^2(x/2))/sec^2(x/2) = (1-t^2)/(1+t^2)
(Try to see if you can get a corresponding result for sin(x)!)
Now onto [itex]\int \sec x \, dx[/itex]. If we let t=tan(x/2), then dt/dx=(1/2)sec^2(x/2)=(1+t^2)/2. So:
[tex]\int \sec x \, dx = \int \frac{1}{\cos x} \, dx = \int \frac{1}{\frac{1-t^2}{1+t^2}} \cdot \frac{2}{1+t^2} \, dt[/tex]
Try to take it from here.
I prefer this way:
[tex]\int \sec x dx = \int \frac{\sec x(\sec x + \tan x)}{\sec x + \tan x} dx[/tex]
[tex]= \int \frac{\sec^2 x + \sec x \tan x}{\sec x + \tan x}dx = ln |\sec x + \tan x| + C[/tex]
Is this right?
the square root of the sum of the squares of the coefficients of the sine and cosine is [tex]\sqrt2[/tex]. Therefore, we multiply both the numerator and the denominator by [tex]\frac{1}{\sqrt2}[/tex]:[tex]\frac{1}{\sqrt2} \int \frac{1}{\frac{1}{\sqrt2}\sin{x}+\frac{1}{\sqrt2}\cos{x}} dx[/tex]
[tex]\frac{1}{\sqrt2} \int<br /> \frac{1}{\cos{x}\cos{\frac{\pi}{4}}+\sin{x}sin{\frac{\pi}{4}}} dx[/tex]
[tex]\frac{1}{\sqrt2} \int \frac{1}{\cos{(x-\frac{\pi}{4}})} dx[/tex]
[tex]\frac{1}{\sqrt2} \int \sec{(x-\frac{\pi}{4})} dx[/tex]
using the integration :[tex]\int \sec{x} dx = ln|\sec{x}+tan{x}|+C[/tex]
[tex]\frac{1}{\sqrt2} ln|\sec{(x-\frac{\pi}{4})}+tan{(x-\frac{\pi}{4})}|+C[/tex]
Is this it?
Looks fine to me.
You first wrote the above and then said this to explain it
Am I just not getting this? It's been known to happen.
Explicitly starting from the sum angle identity (working in radians);
[tex]\cos(A-B) = \sin(A)\sin(B)+\cos(A)\cos(B)[/tex]
Setting [itex]A = x, \;\;\; B = \pi/4[/itex];
[tex]\cos\left(x-\frac{\pi}{4}\right) = \sin(x)\sin\underbrace{\left(\frac{\pi}{4}\right)}_{=1/\sqrt{2}} +\cos(x)\underbrace{\cos\left(\frac{\pi}{4}\right)}_{=1/\sqrt{2}}[/tex]
Multiply both sides by [itex]\sqrt{2}[/itex];
[tex]\sin(x)+\cos(x) = \sqrt{2}\cos\left(x-\frac{\pi}{4}\right)[/tex]
Does that make more sense?
Multiply both sides be [itex]\sqrt{2}[/itex];
Makes perfect sense, thank you! I guess it was just a mind block!
A pleasure, Merry Christmas :smile:
