| Thread Closed |
West Antarctica Total Disintegration - a worse case scenario? |
Share Thread | Thread Tools |
| Dec24-07, 02:14 AM | #1 |
Antarctica has a total of 25.4 million km^2 of ice. West Antactica Ice Sheet (WAIS) has a volume of 2.2 million km^3 of ice. WAIS is that part of Antactica west of transantarctic mountains. The surface of earth is 510,072,000 km^2; while the ocean is 71% of such surface; giving 361 million km^2. So 2.2 million km^3 of ice / 361 million km^2 of ocean surface = 6.1 x 10^-3 km of sea surface rise from WAIS total melt. This is a 6 meter (18 feet) sea surface rise. However one has the caveat, that WAIS is approximately 1000 ft below sea level. So for average ice thickness of 4000 ft, then 1/4 of WAIS melt would seem to stay, forming an archipelago. Therefore resulting in only about 13.5 feet rise in sea level. This then is supposedly one of the worse case scenarios for global warming.
See references: earth.http://http://en.wikipedia.org/wiki/Earth http://en.wikipedia.org/wiki/West_Antarctic_Ice_Sheet |
| Dec25-07, 03:06 AM | #2 |
But over what time span? 100yrs or less, vs 200-500 or 1000 yrs?
| Apr29-08, 12:46 AM | #3 |
Another approach to calculation of sea surface rise: West Antarctica ice sheet thickness is average of 2000 meters. http://www.sciencedaily.com/releases...1218073333.htm
W. Antarctica has a maximum bed depth of -2500 m (i.e. below sea level). So if average depth of bed of W. Antarctica is -1500 m, then approximately 500 m. elevation above sea level for ice sheet. So then just 500 m. of ice x surface area of W. Antarctica would be distributed over world oceans since W. Antarctica is an archipelago. W. Antarctica S.A. is approximately equal to that of Western Australia or 2.6 million km^2. So for total ocean S.A. of 361M km^2, such latter S.A. is equivalent to 139 W. Antarctica; that is, 361M/2.6M = 139. So 500 meters or 1500 ft distributed over 139 W. Australia would give 1500/139 = 10.79 ft sea surface rise world wide. |
| Apr29-08, 05:53 AM | #4 |
here is some likely cause of unstability of the West Antarctic Ice Sheet.
http://www.sciencedaily.com/releases...0120160720.htm |
| Apr29-08, 09:04 AM | #5 |
I do not want to hijack the thread but a related question,
Would significant water depth increase put enough extra pressure on the sea bed, so that earthquake and volcanic activity increases globally? |
| Apr29-08, 09:45 AM | #6 |
If land ice melts, this becomes more *distributed* matter (what was all on one heap is now distributed all over the oceans), and when the water *expands* (because of higher temp) this is not going to change its total weight (and hence pressure). |
| May14-08, 01:20 AM | #8 |
But the point was *global* increase in pressure, which is impossible of course. What can happen is that the redistribution of matter shifts certain equilibria, and gives rise to more, or to less, tectonic activity. |
| May14-08, 09:37 AM | #9 |
Almost certainly more, I should think. The Antarctic continent would have less pressure on it, and the sea floor would have more. The crust would need to shift to adjust to the new distribution.
But has anyone seen a map of what this scenario would mean for coastal regions? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: West Antarctica Total Disintegration - a worse case scenario?
| Disintegration of Particles | Classical Physics | 7 | ||
| disintegration of a particle | Introductory Physics Homework | 5 | ||
| Beta disintegration | High Energy, Nuclear, Particle Physics | 3 | ||
| Learn the general case first, or the special case first? | General Math | 6 | ||
| Total Eclipse of Sol in Antarctica (24/11/03) | General Astronomy | 1 | ||
