| Thread Closed |
Freeze? Turns into gas? |
Share Thread | Thread Tools |
| Dec25-07, 02:29 AM | #1 |
Let's say you have water in liquid form in a closed container on a spaceship in space. Then you bring the container filled with water out from the space ship into free space.
Will the water freeze, stay in liquid form or turn into gas? Assume the container didn't break. |
| Dec25-07, 03:51 AM | #2 |
Assuming the container wouldn't break, the water would stay in liquid form.
The pressure stays the same and the temperature doesn't change as well, so no phase transition for you :). ----- Assaf Physically Incorrect |
| Dec25-07, 03:54 AM | #3 |
Oh, the temperature inside the ship and outside the ship is the same?
| Dec25-07, 04:02 AM | #4 |
Once outside the water has no way of transferring heat - not by convection, nor by conduction (to what? there is nothing in space). It will radiate, but it would take it a looong amount of time to lost its heat energy that way.
| Dec25-07, 06:18 AM | #5 |
What about the radiation from the sun?
| Dec25-07, 09:01 AM | #6 |
Mentor
It actually doesn't take that long to radiate heat away. If shaded from the sun, it could freeze in a few hours. If not shaded from the sun, solar radiation would probably keep it warm (though I'd have to calculate that to be sure).
| Dec25-07, 09:09 AM | #7 |
So the water can, in fact be either in solid, liquid or gaseous state depending on how much is the container shaded from the sun?
| Dec25-07, 03:12 PM | #8 |
Ah, never said anything about the sun :).
Exactly how far from the sun are we talking about? (and we ARE talking about OUR sun, right?) Assaf Physically Incorrect |
| Dec25-07, 04:42 PM | #9 |
If you have an object in a perfect vacuum far far away from any other objects, why shouldn't it emit electromagnetic radiation ? as i see it - it emits the radiation because of its own properties and not only because of the environment. I think it even should be cooled faster if it has no other object around it which can reflect back the radiation it emits, or radiate energy back to it. Does it make sense what I say ? |
| Dec25-07, 05:30 PM | #10 |
The water will not change if the container retains its volume, regardless of any influences.
If the container changes volume then it's a whole different ballpark. |
| Dec25-07, 07:45 PM | #11 |
eh? Anyway.. as other people said. What happens to it depends on how much radiation it receives. |
| Dec26-07, 02:39 AM | #12 |
Recognitions:
Yes this question has way too many undefined parameters to have any meaningful answer, though you could consider a few specific cases.
Case 1. Water in the dark of space in a closed container. In remote space it is very cold (about 3 degrees k background radiation) so yes the water would cool and freeze if contained in a closed container. The radiative cooling need not be that slow. Take for example 1 litre of water enclosed in a 10cm per side cube as an example. If the wall material radiates somewhere close to a blackbody then the rate of loss of energy at say 10C (283k) is about 5.7E-8 * 600E-4 * 283^4, which comes to about 21 Joules per second. One litre requires 1000 Joules per degree C of cooling so that’s about one degree every 50 seconds. For a very rough calculation if the one litre started at around 20C to 25C then it could freeze in as little as about 20 minutes. Case 2. Water in the dark of space in an open container. Space is close to a vacuum, certainly less than the triple point pressure (about 600 Pa) for water, so an open container of water (at say 20C) would immediately boil if removed from the pressurized space-craft into the (near) vacuum of space. In fact it may even boil and freeze at the same time. That is, it might not boil away completely but instead to partially boil away while leaving a frozen residue (that would eventually sublimate (convert directly from solid ice to water vapour). |
| Dec26-07, 07:38 AM | #13 |
Ah, I understand now that water freezes in space far influences such as the sun.
Now I'm interested in the case where our container is somewhere in a geosynchronous orbit above the earth. Will the water stay in liquid form when facing the sun? Will it freeze when earth is blocking the sun? |
| Dec26-07, 11:29 AM | #14 |
If the container resists expansion and contraction, the water will remain in whatever state it started in. |
| Dec26-07, 11:42 AM | #15 |
Okay, let's assume that the container is full with water and it's rigid and indestructible. So, from my understanding of your post is that the water will stay in liquid form even when sunlight shines upon it?
| Dec26-07, 02:40 PM | #16 |
No.. the water will eventually vaporize then plasmarize if the temperture gets high enough.
| Jan2-08, 10:43 PM | #17 |
Plasmarize?
Okay, let's make give the details of the problems... Case 1: A rigid, indestructable, transparent, air tight container full with water is floating in deep dark space far from the sun. Initially the water is in liquid form at temperature 25 degrees celcius. Will the water continue to be in liquid form or will it freeze or turn into gas? From the answers given in previous posts, I understand that the water will radiate away it's heat and freeze in a few hours. Correct? Case 2: A rigid, indestructible, transparent, air tight container full with water is floating in space. Initially the water is in liquid form at temperature 25 degrees celcius. But this time, it receives radiation from the sun. Now this one... depending on the amount of radiation, the water will either stay in liquid form or freeze? Since the container full of water and not expandable, the water cannot turn into gas, correct? Case 3: A rigid, indestructible, transparent, air tight container full with water is floating in deep dark space far from the sun. Initially the water is in liquid form at temperature 25 degrees celcius. This time, the cover of the container is opened. What will happen? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Freeze? Turns into gas?
| Why don't lakes freeze solid? | Chemistry | 12 | ||
| Freeze of water | General Physics | 15 | ||
| Congeal vs. Freeze | Atomic, Solid State, Comp. Physics | 1 | ||
| freeze people | General Discussion | 10 | ||
| Why did the beer freeze? | General Physics | 22 | ||
