Water Flow Rate and Approximations: Insights from a Riemann Sum?
  • Thread starter Thread starter ricekrispie
    Pipe Water
The problem involves analyzing the flow rate of water from a pipe over a 24-hour period, represented by a differentiable function R(t) based on given data points. The tasks include approximating the integral of R(t) using a midpoint Riemann sum, justifying the existence of a time when the derivative of R(t) equals zero, and calculating an average flow rate using an alternative function Q(t).
  • Participants discuss the concept of Riemann sums and their application to the problem. Some express uncertainty about the definition and calculation of Riemann sums. Others suggest focusing on part B, which does not depend on part A.
The discussion is ongoing, with participants seeking clarification on Riemann sums and exploring the implications of the flow rate data. Some guidance has been offered regarding the independence of parts A and B, but no consensus has been reached on the approach to part A.
Participants indicate a lack of familiarity with Riemann sums and express the need for further instruction or resources. There is a mention of homework constraints and the nature of the problem as an AP-level question.
ricekrispie
t (hours) | R(t) (gallons per hour)
0 9,6
3 10,4
6 10,8
9 11,2
12 11,4
15 11,3
18 10,7
21 10,2
24 9,6​
The rate at which water flows out of a pipe, in gallons per hour, is given by a differentiable function R of time t. The table above shows the rate as measured every 3 hrs for a 24-hour period.
(a) Use a midpoint Riemann sum with 4 subdivisions of equal length to approximate [tex]\int_0^{24} R(t) dt[/tex]. Using correct units, explain the meaning of your answer in terms of water flow.
(b) Is there some time t, 0 < t < 24, such that R´(t) = 0? Justify your answer.
(c) The rate of water flow R(t) can be approximated by Q(t) = (1/79)(768 + 23t - t^2).
Use Q(t) to approximate the average rate of water flow during the 24-hour time period. Indicate units of measure.
P.S.: THIS IS AN AP PROBLEM :(
P.S.2: SORRY, I DON´T HAVE A CLUE OF WHERE TO START
For multi-character limits of integration, you need to use {}'s:
[tex]\int_0^{24}[/tex]
The question is basically asking how much water has flowed out of the pipe.
Do you know what a Riemann sum is?
no.. i have no idea
