Time dependent electric force at large distance
The discussion revolves around formulating time-dependent equations to simulate the positions of two electrically charged particles at large distances, considering their initial positions and velocities. The focus is on the challenges of accounting for the non-constant electric force as the particles move closer together over time.
  • One participant presents initial equations for force, acceleration, and position but acknowledges that the force is non-constant due to the changing distance between the particles.
  • Another participant points out that the equation for position given is only valid for constant acceleration, which does not apply in this scenario.
  • There is a discussion about the nature of the vector differential equation and the need to break the force into its respective components in three dimensions.
  • Clarification is sought on the meaning of the constant C in the differential equation, with one participant explaining it in the context of electric forces.
  • One participant expresses a desire to simplify the problem to two dimensions and seeks guidance on continuously expressing the distance between the two charged particles as they move.
Participants generally agree on the complexity of the problem and the need for a time-dependent approach, but there is no consensus on the specific methods or equations to use. Multiple competing views on how to approach the problem remain unresolved.
There are limitations in the discussion regarding the assumptions made about the forces and the mathematical treatment of the problem, particularly concerning the integration of acceleration and the continuous relationship of distance over time.
Shintao
I need some help with time dependent equations. I have two electrically charged particles in space that are at large distances. How would I write a time dependent equation to simulate there positions at give times. I know there initial positions and there initial velocities. And for simplicity one object is unmovable. This is what I have:
[tex]f = \frac{kq_{1}q_{2}}{r^2}[/tex]
[tex]a = \frac{f}{m}[/tex]
[tex]x = x_{0} + v_{0}t + \frac{at^2}{2}[/tex]
But, the force between the two objects is non-constant because as they get closer to each other force increases rapidly. So do I use the yank instead of force. But, that creates the problem of making the equation distance dependent. I don't need the force at given distances. I need the force a given times based on distances.
for those that know C++:
f = cos(atan2(particle2.y - particle1.y, particle2.x - particle1.x)) * COULOMB_CONSTANT * -particle2.charge * particle1.charge / (_hypot(particle2.y - particle1.y, particle2.x - particle1.x));
a = f / particle1.mass;
x = particle1.initial_x + particle1.initial_velocity.x * time + a * pow(time, 2) / 2;
It seems to me that the force should be time dependent because the distance between the two particles is time dependent. I need some calculus help. I think?
First off, this equation does not apply. This is not a general equation, but rather an equation that is only valid for the special case of constant acceleration. And of course, in your situation you already know that the force is not constant.
Here you are dealing with electrical forces, but do you know of any other forces with the same form for their equation? If so, do you know the solution for that equation?
By the way, I don't know your level of math, but this is a vector differential equation that would probably be covered after 3 semesters of calculus or more.
r'' = C/(r |r|)
If you don't know how to solve that, then you are going to have to look up the solution somewhere else.
I looked up differiental equations. When you say vector differiental equation, are you referring to the fact that I have to break the force into its three respective vectors(x, y, z). If that is what you mean, I understand how to pull apart the force vector into the respective parts.
[tex]r'' = \frac{C}{r|r|}[/tex]
I need some help breaking this down. Correct me if I'm wrong. 2nd derivative of r = C/(r|r|). What does C stand for? And wouldn't r have to relate to time and position?
C is just a constant. In this case C = k q1 q2/m1. But if you were dealing with gravity then C = G m1 m2/m1
I should have been more explicit r is actually r(t) = (x(t),y(t),z(t)), a vector function of time indicating the position at a time t.
I get what you are saying. U were just short-hand writting with C in the equation. If I can figure this out it should relate to most of the inverse-squared laws in physics.
r is the three dimensional displacement of the object(electron, e) or the stationary object(proton, p)
For simpicity I just want to use 2 dimensions(x, y)
I start with time(t) = 0;
d = distance between e and p
m = slope
C = k * q1 * q2
[tex]d = \sqrt{(e_{x} - p_{x})^2 + (e_{y} - p_{y})^2}[/tex]
[tex]m = \frac{e_{y} - p_{y}}{e_{x} - p_{x}}[/tex]
[tex]F_{x} = \cos{(\arctan{(m))} * \frac{C}{d^2}}[/tex]
[tex]a = \frac{F}{m}}[/tex]
Then integrate a twice for t to get the new position along the x axis. Then do the same for the y axis. Then start over with the new position. But, since position is related to the distance between the two objects how do I write a continuous equation for the distance between the two objects. d is what I don't know how to do continously.
  • · Replies 22 ·
