How does kinetic friction change around a curve
Kinetic friction experienced while running around a curve increases due to the normal force, which is influenced by the runner's velocity and the radius of the turn. Specifically, the normal force can be calculated using the formula {(v^2/r) + (weight of runner * gravity)} * (kinetic friction coefficient). This relationship holds true at any point along the curve, where the local radius of curvature determines the dynamics of friction. The discussion confirms that both static and dynamic friction are affected by the curvature of the path.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of normal force and kinetic friction
  • Basic knowledge of circular motion dynamics
  • Awareness of the coefficient of friction and its application
  • Research the mathematical derivation of friction in circular motion
  • Explore the effects of varying radius on frictional forces
  • Learn about the role of velocity in dynamic friction scenarios
  • Investigate real-world applications of friction in sports and biomechanics
Physicists, sports scientists, athletes, and anyone interested in the mechanics of motion and friction in curved paths.
kingkongsr.
If I am running in a straight line, and I am experiencing kinetic friction that is proportional to my weight, i.e. my normal force, then when I run around a curve, does my normal force increase by my velocity squared divided by the radius of the turn as if it were a perfect circle ( {(v^2/r)+([weight of runner]*gravity)}*(kinetic friction coefficient) = kinetic friction)?
You experience static friction when you run. There is no relative motion between your shoes and the ground.
As for your main question, yes. The normal force, and thus the static or dynamic friction, increases due to the turn. The radius is the local radius of curvature at that instant along the curve. You can think of it as a perfect circle of radius, r, at that point along the curve at that instant. (Each point along the curve has a different radius for any general curve, if the curve is a circle the the radius is the same at all points along the circle)
thank you Cyrus.
thank you very much Cyrus. I just needed a second opinion other than my own
  • · Replies 77 ·
  • · Replies 20 ·
  • · Replies 37 ·
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 19 ·
  • · Replies 34 ·
