Are propositions and theorems interchangeable in mathematics?
  • Context: Undergrad
  • Thread starter Thread starter jostpuur
    Theorem
The discussion revolves around the terminology used in mathematics, specifically whether propositions and theorems are interchangeable. Participants explore the distinctions and similarities between various mathematical statements, including axioms, propositions, theorems, lemmas, and corollaries, within the context of their presentation and perceived importance.
  • Some participants question the consistency in labeling statements as theorems or propositions, suggesting that it may appear arbitrary or random in certain texts.
  • Others argue that the distinction between terms like "theorem" and "proposition" is largely a matter of presentation, with some suggesting a hierarchy of importance among different types of statements.
  • One participant notes that while theorems are often seen as main results, lemmas serve as intermediate results, and corollaries follow directly from theorems, indicating a structured approach to these terms.
  • There is mention of Zorn's lemma as an example where the lemma is considered more significant than the theorem it supports, highlighting the complexity of these classifications.
  • Another participant points out that not all propositions are proven true, and some may even be disproven, emphasizing the context and motivation behind their use in mathematical discourse.
Participants express differing views on the interchangeability of propositions and theorems, with no clear consensus reached. The discussion reflects a variety of perspectives on the significance and classification of mathematical statements.
Participants acknowledge that the definitions and importance of terms may vary across different works, and the motivations behind labeling statements can influence their classification. There is also an indication that some statements may be considered theorems in one context but not in another.
jostpuur
What are propositions? When I read lecture notes, it seems that some of the theorems are randomly called propositions instead.
The difference between terms like "axiom", "proposition", "theorem", "lemma", and "definition" are pretty much just a matter of presentation.
(Actually, the term "proposition" is also used to refer to any statement, not just 'true' ones)
I see... but when text goes like this:
Theorem 1.n. blablablablablabla
Proof. blablablablabla [itex]\square[/itex]
Proposition 1.(n+1). blablablablablabla
Theorem 1.(n+2). blablablablablabla
It means that some of the theorems are being called propositions randomly? :rolleyes: I wonder if the author has been using dice when writing this.
It's not uncommon to have multiple 'types' of statements share the same counter. For example, it's a lot easier to find example 1.5 when it lies between theorem 1.4 and lemma 1.6. ;)
As to why to label a statement as being a theorem and another a proposition, I would guess that the author felt that the theorems are more important statements.
A lemma, theorem and corollary are all statements that must / should be proven, though there is a sort of intuitive distinction between them. IMO there is a tacit agreement that, for example, Theorems are main results, while Lemmas are often intermediate results needed to prove a theorem (though I have seen cases where the lemma was more general, interesting and important than the theorem whose proof it was needed for); Corollaries are usually short statements which follow (almost) immediately from a given theorem (or they are special cases of those). I often see Propositions following a Definition, in which certain properties of a newly defined object are shown. In my feeling, a proposition is the kind of statement you are usually willing to take for granted unless you are really picky.
So though Hurkyl is right that it's mostly just a matter of presentation, there is a sort of hierarchy as to which is more important (and then which name is given to which result is largely arbitrary and left as a choice to the author, though the idea is that the names are chosen such that they actually add a logical structure in much the same way as divding the text into chapters, sections and paragraphs does)
Zorn's lemma is a famous example. I've heard he was actually quite annoyed that nobody remembers what he used it to prove! :smile: (though that's probably just an urban legend)
I knew what kind of purpose lemmas and corollaries have in terminology, but for propositions I had no clue.
This must be a Zorn's mistake. He underestimated his own theorem!
Not all propositions are proven true and some are disproven to illustrate or emphasize a point. It all depends on the motivation of the work and should one look closely certain propositions will be theorems in other works as per their importance in deriving the seminal result therein; Indeed here lies an overlooked part of expositions and the considerations need to be in line of definition to proposition to proof(or disproof). Not definition to theorem to proof.
  • · Replies 18 ·
  • · Replies 73 ·
10K
