Solving Problems: Combinations and Permutations
The discussion revolves around two combinatorial problems: selecting books from a shelf containing multiple copies and determining the arrangements of letters in envelopes such that no letter is correctly placed. The scope includes mathematical reasoning and problem-solving strategies related to combinations and permutations.
  • One participant proposes a formula for the first problem as m*(m+n) but later revises it to S=m*(n+m) if m>n and S=n*(n+m) if m
  • Another participant suggests that if n=1, the answer should be 2^m and questions the examples checked by others.
  • A different participant argues that for each book, there are (n+1) possibilities, leading to a formula of (n+1)^m, with a caveat about the empty selection.
  • Concerns are raised about the validity of including the empty selection in the total count of combinations.
  • Discussion on the second problem references the inclusion-exclusion principle, with one participant explaining the relationship between events where letters are correctly or incorrectly placed.
  • Questions arise about the logic behind considering the empty selection as a valid choice and inquiries about the inclusion-exclusion principle and where to learn more about it.
Participants express differing views on the correct approach to the first problem, particularly regarding the inclusion of the empty selection and the application of formulas. The second problem also generates discussion about the inclusion-exclusion principle, indicating that multiple competing views remain on both problems.
Participants have not reached consensus on the formulas for the first problem, and there are unresolved questions about the treatment of the empty selection. The discussion also highlights varying levels of familiarity with combinatorial principles.
xt
I got this two problems, I can't figure them out...
A bookshelf contains m different books and n copies of each. How many different selections can be made from them?
and
In how many different ways can four letters be posted in four envelopes so that no one receives the correct letter?
and
for the first question maybe it is:
m*(m+n)
but i only checked it for two specific cases.
edit:
after checking again i think the answer should be:
if m>n than S=m*(n+m)
if m<n than S=n*(n+m)
If n=1, then the answer ought to be 2^m, so which examples did you check?
1. For each book, you can take 0 of that book, or 1 of that book, ..., or n of that book. That is (n+1) possibilities. Since we have m books, the formula is (n+1)(n+1)(n+1)...(n+1) m times, or (n+1)^m.
One of the possibilities is that we select 0 of every book, so if "none of the books" is not a valid selection, then it is (n+1)^m - 1.
i didnt try it for n=1.
the cases are:
m=2 n=3
and m=2 n=4
perhaps the flaw is i should have put in the second case m different than 2.
bougar :frown:
i tried with n=1 and m=2 and here are the combinations i got:
(1,1)
(1,0)
(0,1)
if you put it in your formula it equals to 2^2=4 which is one combination more than in reality.
(unless you include (0,0) a selection which i haven't included in my two examples).
The empty selection is always a selection.
pig's answer is correct assuming that the wording implies that picking anyone of the n copies is the same event as picking any of the other of the n copies.
The second question follows from the inc-exc principle.
Let V_n be the event that the nth person gets the right letter, U_n the even they don't
Then doing the event you want is the intersection of the V_i which is the complement of the union of the U_i, which can be found using inclusion exclusion
whats the logics behind this? why do you assume its a selection first then after the solution is done minus it off and say its not a valid selection?
matt grime said:
inc-exc principle.
what is that? where can i learn this stuff from? elementary probability?
  • · Replies 20 ·
  • · Replies 31 ·
