New Reply
Kinoki Foot Pads
Share Thread Thread Tools
Dec29-07, 10:01 PM   #1
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Kinoki Foot Pads
Why use Kinoki Detox Foot Pads?
Formulated in Japan using all-natural tree extracts and powerful negative ions Kinoki Foot Pads help rid the body of harmful toxins. Kinoki Foot Pads purge toxins safely and effectively.
https://www.buykinoki.com/?cid=398358
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Dec30-07, 12:29 AM   #2
Recognitions:
Holy Cow! If I wasn't so heavily invested in Chia Pets, I'd dump everything into Kinoki Foot Pads! What an innovation!
Dec30-07, 11:17 PM   #3
Recognitions:
Hey I heard about these last weekend. There is a mcgill university professer of chemistry that does a radio show out of montreal on CJAD that is simulcast here in Toronto on cfrb. His name is Dr joe schwartz. He does a 1 hour show on chemistry in our everyday lives. He did a quick discussion on these pads with the explanation that the sweat from your feet activate some chemicals in the pads that produce brown staining.This staining is purported to be "bad " chemicals comeing out of your body. Dr Joe says it is a hoax. He goes well into investigating this kind of thing to determine if these types of things are usefull or quackery. Dr. Joe's radio show http://www.cjad.com/shows/19157
Dr.Joes University page http://oss.mcgill.ca/
Past Dr Joe shows. http://oss.mcgill.ca/joeshow-a.php
Dec31-07, 04:50 PM   #4
Recognitions:
Kinoki Foot Pads
Do they at least absorb the sweat and prevent stinky feet? Or are they totally useless?
Dec31-07, 05:12 PM   #5
Recognitions:
Quote by Moonbear View Post
Do Kinoki Foot Pads at least absorb the sweat and prevent stinky feet?
For that we have another ancient Japanese secret: Dr Scholls foot pads
Jan15-08, 10:40 AM   #6
CEL
http://skeptoid.com/episodes/4083
Since the Kinoki foot pads are self-adhesive, peeling them away removes the outermost layer of dead skin cells. And since they are moist, they loosen additional dead cells when left on for a while. So it's a given that the pads will look brown when peeled from your foot, exactly like any adhesive tape would; though this effect is much less dramatic than depicted on the TV commercials, depending on how dirty your feet are. And, as they predict, this color will diminish over subsequent applications, as fewer and fewer of your dead, dirty skin cells remain. There is no magic detoxification needed to explain this effect.
Jan15-08, 11:29 AM   #7
Recognitions:
I've seen the infomercials on those things. I just about spit my drink out when I saw it. They even go through chemical analysis of what was in the pad after the next morning. Wow!
There is indeed a sucker born every minute.
Jan17-08, 04:36 PM   #8
This was a few years ago. My boss, of that era, purchased these from an older couple who sold them around town. I received them as a gift, long before commercial days for this product.
I used them for about a week. I wore them all day, every day till the pads stopped turning dark brown. There was no adhesive on these. They were outwardly designed like a very expensive bandage (or feminine maxi.) The inner layers were consistent with a very absorbent maxi, tho you can feel there is a gritty type substance in the middle, like dry herbs.
The first day the pads were black. You notice there is moisture within the pad. It is damp and sticky. The next couple days they're more dry, less moisture appears to be inside. The moisture concentrates to an area around the middle. They finally end up coming out with no moisture and no visible darkness. My feet seem to feel less moist at the end of the day after using these. A co-worker used them at the first signs of a cold, and he turned out much better than what he anticipated at first signs of illness.
The article boasts a natural herb with some type of negative ionic effect. Is it probable that this be true? For those that are claiming this is a scam, provided with my testimony, do you have any explanation for the results I received?
What can these pads consist of, that would produce such result? As a 'green' business owner and retail provider, I may like to carry these if the likelihood, that they work, is greater than not. I appreciate any help regarding answers to these questions.
Many blessings of Joy & Fruit, may Life be a Smoothie.
Angel of Organic Earth
Jan17-08, 05:12 PM   #9
Evo
Mentor
Quote by AngelsWalk View Post
The only "benefit" from such an item is a "placebo" effect, it's not real. If your feet perspire less with continued use, there could be an antiperspirant in the pads. There could also be a chemical in the pad that reacts to moisture, the less moisture, the less darkening.
Jan17-08, 06:01 PM   #10
Recognitions:
They don't even claim to reduce perspiration.
Angelswalk, one or two anecdotal and subjective reports mean nothing. If you can produce test data from a nationally recognized lab that shows that body toxins were reduced after use, that would be another thing. But you won't find any because this is absolute nonsense.
Note that someone who didn't get as sick as they expected is not a test of anything. It means nothing. We have no idea how sick that person would have been otherwise. But I would bet the farm that if we could know, the difference was zip.
Jan17-08, 07:02 PM   #11
Why don't one of you do a test? Use the pad for a night and then see what is in it? I'm sure one of you has lab access. I think it is a scam, but it would be easy to disprove once and for all.
Jan17-08, 09:43 PM   #12
I suspect some form of tannic acid in them, which turns dark brown with sweat/salts.
Jan17-08, 10:00 PM   #13
Maybe tea leaves. No more foot oder when using tea. Also, if you perspire the tea would get wet and then brown.
Jan20-08, 09:20 AM   #14
Admin
If Kinoki Foot Pads are a scam, why aren't they investigated?
Jan20-08, 09:29 AM   #15
Recognitions:
Quote by Greg Bernhardt View Post
For the same reason that copper bracelets, homeopathic "medicines", magnetic innersoles, etc aren't investigated. Quacks make a lot of money on this stuff, and there is little incentive to spend time and money to debunk them. As long as these products don't harm people, the government won't go after them.
Jan20-08, 09:31 AM   #16
Mentor
The FDA is not given jurisdiction over the "Natural" or alternative medicine industry. Thanks to their lobbying efforts in congress, they are exempted from producing clinical data to support their claim. That's why you can also see those "homeopathic spray" commercials. Only after there is a health scare do the authorities step in.
Zz.
Jan20-08, 10:14 AM   #17
Admin
Quote by ZapperZ View Post
Zz.
Can't these scam companies be sued for false advertising if the product doesn't work as described?
New Reply
Thread Tools
Similar Threads for: Kinoki Foot Pads
Thread Forum Replies
Heat Due to Friction In Brake Pads Materials & Chemical Engineering 27
Okay, here is my hypothetical situation. Lets say there is a cylinder General Physics 2
Vias in SMT pads Electrical Engineering 2
Heat Due to Friction Between Brake Pads Classical Physics 1
hot brake pads on a car Classical Physics 15
