Angular Momentum -Opening a door with a bullet
The discussion revolves around a physics problem involving angular momentum, specifically related to a cowboy attempting to open a saloon door using a bullet. The problem includes deriving expressions for the moment of inertia of the door, the angular velocity after impact, and the maximum angle the door will open, given specific parameters.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss deriving the moment of inertia for the door and the angular velocity using conservation of angular momentum. There are questions about the correct expressions and whether to include the bullet's contribution to the system's rotational inertia.
Some participants have provided guidance on using conservation of angular momentum and integrating energy considerations related to the spring mechanism of the door. There is an ongoing exploration of the correct formulations and assumptions, particularly regarding the contributions of the bullet and the door's inertia.
Participants are navigating potential language translation issues regarding terms like "angular benchmark" and are considering the implications of the door being on a spring mechanism. There is also a focus on ensuring all relevant factors, such as the initial momentum of the bullet and the rotational inertia of both the door and bullet, are accurately accounted for.
Vickitty
Sorry for so many questions, just coming back here after going through all the review questions I could get. Here we go:
A cowboy wants to open a saloon door with a revolver shot. The swinging door (Mass M, width b) is hit on the very edge and the bullet (Mass m, velocity v) lodges into the door.
a) Derive an expression for the moment of inertia of the door. - I got this to be J = Mb^2/3, and not too worried about this question.
b) Derive an expression for the angular velocity w, with which the door swings open after being hit. -I'm supposed to use the conservation of angular moment here, right? I ended up getting w = 3mv/((M+m)b^2), but I don't think this is right.
c) How many degrees will the door open at most, with D* as the "angular benchmark"? Use the numbers M = 10 kg, b = .6 m, m = 10 g, v = 500 m/s, D* = 1.2 Nm. - I don't even know if "angular benchmark" is the right translation for D* (it's Winkelrichtgroesse in German if that helps anyone). We were also given the formula Moment of Force = -D*phi. Am I going to want to plug the info I'm given into the formula I created in b?
Thank you again.
Right.
Yes, use conservation of angular momentum. But you need the rotational inertia of the "door + bullet", not just the door. (It's a tiny correction.)
Assuming by "moment of force" is meant a restoring torque acting to close the door (it's on a spring), then find energy stored in it as a function of angle. (Integrate; or just compare to a spring.) Then find the KE that the system has after impact, using the results of step b. Then consider that KE is transformed into spring potential energy.
Doc Al said:
Right.
I used mv = (M + m)b^2w/3, which is including both the door and the bullet, isn't it? Or do you mean in the initial momentum of the bullet as well? The door has no momentum to start off with though.
In this problem all you care about is the angular momentum of the bullet (rotating about the door hinge). The balance of the linear momentum will be taken up by the door hinge.
Part b:
The angular momentum of the bullet should be [tex]|\vec{p} \times \vec{r} | = mvb[/tex] (angular speed should be in per second - you had per meter second). And, since [tex]M>>m[/tex] you can just use [tex]\omega\approx\frac{3mv}{Mb}[/tex]
Part d: The saloon door is on a spring that's working against the bullet. D is effectively the spring constant for the door. You should be able to solve this using energy.
You are leaving out a "b" (in the initial angular momentum of the bullet) and are not capturing the rotational inertia of the bullet properly:
mvb = (1/3M + m)b^2ω, so ω = 3mv/(M+3m)b.
But as NateG says, you can ignore the bullet's small contribution to the rotational inertia (3m compared to M), so ω ≈ 3mv/Mb.
  • · Replies 57 ·
  • · Replies 71 ·
18K
