| Thread Closed |
[SOLVED] Gravitation & Escape Speed - Stone leaving Earth and reached the Moon. |
Share Thread | Thread Tools |
| Dec31-07, 02:14 AM | #1 |
Hello everyone, I have one question on gravitation and escape speed. In the earlier part of the question, the minimum speed for the stone to leave the Earth is calculated and its final destination is the Moon.
In the next part, the question asks if the stone will hit the Moon with a speed greater than or smaller than the minimum speed calculated in the previous part. Can anyone help me with the above question by providing a suitable explanation as well? Many thanks in advance. |
| Dec31-07, 03:24 AM | #2 |
Have you tried the conservation of energy law?
| Dec31-07, 03:26 AM | #3 |
| Dec31-07, 03:32 AM | #4 |
Well, conservation of energy will enable to calculate the value of the speed, so you'll know if it is more or less smth else. Do you know the formula for gravitational potential energy and also for kinetic energy?
| Dec31-07, 04:00 AM | #5 |
I apologize for the misunderstanding. |
| Dec31-07, 04:06 AM | #6 |
Oh yes, I see, my bad. Maybe there's a shorter way, but I'd still calculate the velocity at the Moon's surface to obtain a figure, and then just compare the two.
| Dec31-07, 04:09 AM | #7 |
| Dec31-07, 04:12 AM | #8 |
I suggest you to calculate the speed of stone as it reaches the Moon's surface (assume a head-on collision for a greatest possible speed).
| Dec31-07, 04:13 AM | #9 |
You have now TWO gravitational potentials; that from the Earth, and that from the Moon
Letting R be the distance the stone has from the Earth centre, r the distance it has from the Moon centre, conservation of mechanical energy means: [tex]\frac{1}{2}mv^{2}-\frac{Gm_{e}m}{R}-\frac{Gm_{m}m}{r}=C[/tex] where m is the stone's mass, me the Earth mass, mm the moon mass and G the universal gravitation constant (C being the constant value of the energy). See if you can use this. |
| Dec31-07, 04:21 AM | #10 |
I do not actually need to solve and calculate a value and I am also unable to due to the lack of information provided in the question. I am, however, required to explain it. Can you help me phrase this in words? (making it a little clearer for me to understand as well ;-) ) |
| Dec31-07, 04:26 AM | #11 |
| Dec31-07, 04:31 AM | #12 |
| Dec31-07, 04:36 AM | #13 |
Yes but as arildno, pointed out you have TWO gravitational potentials.
That means that the stone feels two forces one from the Earth and one from the Moon. The escape velocity depends from both. |
| Dec31-07, 04:39 AM | #14 |
| Dec31-07, 04:44 AM | #15 |
Think aboout the forces that acting on the stone when you throw it away.
The force from the Earth resists or helps the stone to move? What about the force from the Moon? And futhermore, what happens to the values of the two forces while the stone is moving? |
| Dec31-07, 04:49 AM | #16 |
I don't see how it affects the minimum speed. I don't want the stone to escape the Moon's pull as well. I want the stone to land on the Moon. Sorry, but I am really lost right now. ): |
| Dec31-07, 04:52 AM | #17 |
Here, I must disagree with your interpretation, Rainbow Child:
I think you are to USE the escape velocity, as calculated in the first part, and then calculate the impact velocity on the moon. For simplicity, I'll regard the distance between the Moon and the Earth, D as a constant. Let Re be the Earth radius, Rm the moon radius, then the conservation of energy tells us: [tex]\frac{1}{2}mv_{i}^{2}-\frac{Gm_{e}m}{D+R_{e}}-\frac{Gm_{m}m}{R_{m}}=\frac{1}{2}mv_{e}^{2}-\frac{Gm_{e}m}{R_{e}}-\frac{Gm_{m}m}{D+R_{m}}[/tex] where ve is the calculated escape velocity, and vi the impact velocity you were to find. Now, rearrange terms and evaluate what terms are greater than others. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Gravitation & Escape Speed - Stone leaving Earth and reached the Moon.
| Leaving Earth | General Discussion | 70 | ||
| moon earth system escape velocity | Introductory Physics Homework | 1 | ||
| [SOLVED] Acceleration of Guns firing on Moon and Earth Problem--HELP!! | Introductory Physics Homework | 1 | ||
| Is the moon leaving us? | General Astronomy | 15 | ||
| Moon and tides (tide on the moon instead of earth) | General Physics | 7 | ||
