Thread Closed
Quadratic formula
Share Thread Thread Tools
Jan5-08, 08:17 PM   #1
Quadratic formula
Regarding [tex]\displaystyle{\frac{-b \pm \sqrt{b^2 - 4ac}}{2a}}[/tex]
How should "[tex]\displaystyle{\pm}[/tex]" be treated?
I know a square root can be both possitive and negative, but does the quardratic forumla dictate that a possitive root should be added to -b, or does it dictate that a postive root should be subtracted from -b???
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Jan5-08, 08:25 PM   #2
Mentor
The quadradic forumal yields 2 roots. You do both.
Jan5-08, 08:46 PM   #3
Recognitions:
Homework Helper Homework Help
Some people get confused because other times they see the plus/minus sign, they have to choose correctly, whilst in this case you do it both. Thats why you may also see the formula written as;
[tex]x_1= \displaystyle{\frac{-b + \sqrt{b^2 - 4ac}}{2a}}[/tex]
[tex]x_2 = \displaystyle{\frac{-b - \sqrt{b^2 - 4ac}}{2a}}[/tex]
Jan5-08, 08:53 PM   #4
Quadratic formula
Quote by Integral View Post
Sorry, I'm a little confused.
Say a particular solution to a quadratic equation is [tex]\displaystyle{\frac{2 \pm \sqrt{7}}{3}}[\tex]
If 7 was a perfect sqaure, would the root get added to or subtrected from 2?
Jan5-08, 08:56 PM   #5
Recognitions:
Quote by Holocene View Post
Say a particular solution to a quadratic equation is [tex]\frac{2 \pm \sqrt{7}}{3}[/tex]
If 7 was a perfect square, would the root get added to or subtracted from 2?
It doesn't matter if 7 is a perfect square or not (and it isn't). There are TWO roots to a quadratic equation, hence the quadratic formula has TWO solutions. One of the solutions is when you add the square root part, the other solution is when you subtract it. Look at my previous post.
Jan5-08, 09:06 PM   #6
Quote by Gib Z View Post
Okay I've got it. The 2 solutions are adding a possitive root, and subtracting a possitive root, correct? (Subtracting a negative root is = to adding it, adding a negative root is = to subtracting it).
Jan5-08, 09:13 PM   #7
Recognitions:
[itex]\sqrt{x}[/itex] is used to denote the positive square root of x. Thus [itex]\sqrt{4}=2[/itex] is correct while [itex]\sqrt{4}=\pm2[/itex] is incorrect. Thinking that the latter is correct is too common a mistake - make sure you aren't making it.
Jan5-08, 10:13 PM   #8
Quote by morphism View Post
Got it, thanks.
Thread Closed
Thread Tools
Similar Threads for: Quadratic formula
Thread Forum Replies
Velocity using quadratic formula- NEED HELP PLEASE!!!! Introductory Physics Homework 29
Quadratic Formula Question General Math 3
Quadratic Formula Precalculus Mathematics Homework 5
Quadratic Formula Introductory Physics Homework 9
Quadratic formula help ..... Introductory Physics Homework 3
