| Thread Closed |
Why don't we drop medical waste and nuclear waste into active volcanoes? |
Share Thread | Thread Tools |
| Jan6-08, 01:30 AM | #1 |
Why don't we drop medical waste and nuclear waste into active volcanoes? Aren't the temperatures in these volcaneous high enough to obliterate hazardous waste?
| Jan6-08, 05:52 PM | #2 |
If they are active volcanoes, the volcano might erupt and the waste would be spread all over. It has been considered to drop the waste into the rifts between the tectonic plates, I don't think it's been done though.
| Jan6-08, 06:11 PM | #3 |
I remember that episode from Futurama in which a big spaceship was built to carry away the waste from Earth. Now that's a good idea :-]
| Jan6-08, 09:34 PM | #4 |
Recognitions:
Why don't we drop medical waste and nuclear waste into active volcanoes?1. It would have to be enormous. 2. In case of an accident on launching the fallout could be disasterous. |
| Jan7-08, 03:14 AM | #5 |
For nuclear waste, that's the last thing you want to do with it! The radioactive nature of the material is not altered by the "low" temperatures of a few thousand degrees, which only affect the chemical state and not the nuclear state. You'd need something much hotter to "incinerate" nuclear waste, of the order of a few million degrees at least (like the core of the sun). The only thing a volcano would do, is to spread out quite effectively the radioactive material in the biosphere. Kind of "superchernobyl" style of exercise ![]() The best thing you can do with nuclear waste is to keep it shielded away from the biosphere for a few hundreds / few thousands of years: it decays by itself. You want, at all price, to avoid it being spread massively around too early. That's why deep geological burrying is the "standard" solution to the nuclear waste problem. You want to keep it there for a few hundreds or a few thousands of years. Think of gas an oil and coal who have been confined for hundreds of millions of years in geological confines. A few thousand years shouldn't be such a problem. The last thing you want is to have it in an active volcano. BTW, the fact that it decays by itself is one of the favorable properties of nuclear waste, which is not the case with certain kinds of chemical waste for instance. Heavy metals remain heavy metals for ever. The next best thing to do with it, is to transform it actively. Although this can in principle be done, it is technologically an enormous challenge. Sending nuclear waste in space is an idea that comes up regularly, but is basically flawed: the dangers of a failed launch are too great, the price is too high, etc... compared to the "standard" solution of deep geological burrying. |
| Jan7-08, 08:07 AM | #6 |
nuclear waste: Volcanos do not destroy nuclear waste. [ EDIT ] I could have sworn Vanesch's post wasn't there when I posted mine... |
| Jan7-08, 09:46 AM | #7 |
I thought that Uranium would reduce to Lead anyway. So just because it's producing less radiation doesn't make it safe.
| Jan7-08, 11:48 AM | #8 |
| Jan8-08, 05:58 AM | #9 |
The total fission energy content of 1 kg of uranium corresponds to the total combustion energy of 1500 ton of coal. So heavy metals present in coal on the level of the PPM are (without any retention) released into the biosphere at a greater quantity than those generated by fission for the same amount of energy. Here, you find some interesting information: http://www.ornl.gov/info/ornlreview/...t/colmain.html For instance, it is estimated that from the burning of ~600 billion tons of coal worldwide in about 100 years, about 2 million tons of thorium and about 0.8 million tons of uranium will be released in the biosphere. In fact, the nuclear energy content of this material (which is present in coal, and is hence released in the ashes and smoke) is bigger than the combustion energy content! In this http://www.osti.gov/bridge/servlets/...ative/2069.PDF report, on p12, we find tentative compositions of some coal variants. Note that lead is present in the order of tens to almost hundred of ppm! So we see that simply from one single source of heavy metal pollution of the biosphere, namely coal burning, we pollute already a few orders of magnitude more (for the same energy extraction) than its equivalent pollution by decay of radioactive waste *after its eventual full release to the biosphere* which is not intended. |
| Jan8-08, 01:47 PM | #10 |
Recognitions:
Where nuclear is much more favourable is in the occupational health side: 6,000 miners die each year mining coal in China. Hundreds of thousands die prematurely each year from breathing the effects of burning coal. There is no perfect fuel but nuclear is better than coal on just about every issue. AM |
| Jan8-08, 11:46 PM | #11 |
| Jan9-08, 12:31 AM | #12 |
Recognitions:
and besides, if we use the volcano for destroying medical/nuclear waste then what will we use to sacrafice our virgins?
| Jan9-08, 09:11 AM | #13 |
| Jan9-08, 11:13 AM | #14 |
| Feb16-08, 02:23 AM | #15 |
| Feb16-08, 03:11 AM | #16 |
I've been thinking recently - what if we took nuclear waste, pulverized it (carefully, of course), and mixed it in with with concrete at a dilution that makes it no more radioactive than uranium ore. Then take the concrete and use it to fill in played-out mines (not necessarily uranium mines, just any mine at all, selected for not being under the water table, etc.) Would we end up with any dangers greater than what is naturally present in the environment anyway?
| Feb16-08, 09:37 PM | #17 |
Why does your title not match your actual post?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why don't we drop medical waste and nuclear waste into active volcanoes?
| Would it be feasible to dump nuclear waste inside active volcano's | Nuclear Engineering | 20 | ||
| nuclear waste. | Nuclear Engineering | 8 | ||
| Nuclear waste | High Energy, Nuclear, Particle Physics | 2 | ||
| Nuclear waste | Nuclear Engineering | 15 | ||
