Centre of mass vs. centre of gravity
The discussion focuses on the distinction between the centre of mass and the centre of gravity, particularly in the context of a symmetrical solid body, such as a cone. It establishes that the centre of mass is located at the geometric centre for uniform density, while the centre of gravity can shift based on the gravitational field strength. Specifically, when moving from Earth to Jupiter, the centre of gravity is lowered, making the body harder to tip over. The conversation also raises the question of whether a formula exists to calculate the centre of gravity in different gravitational fields.
  • Understanding of centre of mass and centre of gravity concepts
  • Familiarity with gravitational fields and their effects on objects
  • Basic knowledge of geometry related to solid bodies
  • Awareness of uniform density and its implications in physics
  • Research the mathematical relationship between centre of mass and centre of gravity
  • Explore gravitational field strength variations on different celestial bodies
  • Learn about the stability of objects in varying gravitational environments
  • Investigate existing formulas for calculating centre of gravity in non-uniform fields
Physics students, educators, and engineers interested in mechanics, gravitational effects on solid bodies, and stability analysis in varying gravitational fields.
Kacker
consider a symmetrical solid body. we say its centre of mass is at its geometric centre. that is, for uniform density we've taken mass to vary exactly as volume. now when the same body is taken from a place of gravitational field A to gravitational field B. say from the Earth to jupiter, this body (consider it to be a cone) would be harder to tip over were it standing on its base. that is because , for a body to tip over, the vertical line through the centre of gravity should pass outside the base. the geometry of the body unchanged, we say its centre of gravity is lowered in this stronger field. is there a formula by which we can calculate the centre of gravity in particular fields in relation to those in others?. I am assuming we take centre of gravity and centre of mass to coincide on Earth for convinience's sake.
  • · Replies 31 ·
  • · Replies 51 ·
  • · Replies 32 ·
  • · Replies 17 ·
12K
