How to Change Variables for Integration in Quantum Mechanics?
The discussion revolves around a quantum mechanics problem involving an electron in an infinite one-dimensional well and the application of perturbation theory to determine energy level shifts. The specific focus is on changing variables in an integral related to the perturbation potential.
  • Mathematical reasoning, Assumption checking
  • Participants explore the change of variables from x to φ and discuss how this affects the limits of integration. There is a focus on ensuring the prefactor is calculated correctly after substitution.
Participants are actively engaging with the problem, confirming calculations, and providing supportive feedback. There is a productive exchange regarding the variable transformation and its implications for the integral.
Some participants express uncertainty about the perturbation theory aspect and the qualitative implications of the results, indicating a potential gap in understanding that may need further exploration.
raintrek
[SOLVED] Integration change of variables
An electron is confined in an infinite one dimensional well where 0 < x < L with L = 2 x 10^-10m. Use lowest order perturbation theory to determine the shift in the third level due to the perturbation:
[tex]V(x) = V_{0}\left(\frac{x}{L}\right)^{2}[/tex]
where [tex]V_{0} = 0.01eV[/tex].
After a change of variables, the following integral will be useful:
[tex]\int^{3\pi}_{0}\phi^{2}sin^{2}\phi d\phi = \frac{9}{2}\pi^{3} - \frac{3}{4}\pi[/tex]
I've evaluated this question into the following integral:
[tex]\Delta E_{3}^{(3)} = \frac{2}{L}\frac{V_{0}}{L^{2}}\int^{L}_{0} x^{2} sin^{2}\left(\frac{3\pi x}{L}\right) dx[/tex]
However I have no idea how to "change variables" with an integral like this, let alone how to get the limits change from 0-L to 0-3pi. Can anyone offer assistance? Many thanks in advance...
I believe the change of variables they use is
[tex]\frac{3\pi x}{L} \rightarrow \phi[/tex]
So clearly as [tex]x \rightarrow L[/tex] , [tex]\phi \rightarrow 3\pi[/tex]
hmm, if that was the case, wouldn't the equation take the form
[tex]\Delta E_{3}^{(3)} = \frac{2}{L}\frac{V_0}{L^2}\frac{L^{3}}{(3\pi)^{3}}\int^{3\pi}_{0}\phi^{2}sin^{2}\phi d\phi[/tex]
(Note the L^3/... prefactor) ??
So then can't you plug in for
[tex]\int^{3\pi}_0 \phi^2 \sin^2{\phi}d\phi[/tex]
which you are given? I don't see the problem.
^ I can, I was just seeking assurance that I'd calculated that L^3 prefactor correctly after substitution...
It all looks correct... I know nothing about perturbation theory, so I can't say if the answer qualitatively makes sense with no L dependence.
Yep, that works good, thanks for your help nicksauce!
