Question re GP-3 orbiting gyroscopes test of relativity
The Gravity Probe B (GP-B) mission is a test of General Relativity (GR) utilizing orbiting gyroscopes to measure the frame-dragging effect caused by Earth's rotation. Scheduled for launch on June 26, 2003, the spacecraft is equipped with four cryogenic gyroscopes and precise sensors to detect any tilt in their axes. This mission aims to distinguish between Einstein's model of gravity and alternative theories, addressing a long-standing challenge in physics that has been in preparation for approximately 30 years. The discussion also touches on Mach's Principle and its implications for understanding inertia and motion in relation to the universe.
  • Understanding of General Relativity (GR)
  • Familiarity with gyroscopic motion and frame-dragging
  • Knowledge of cryogenic technology and its applications
  • Basic concepts of Mach's Principle in physics
  • Research the results and findings of the Gravity Probe B mission
  • Explore the implications of frame-dragging on modern physics
  • Study the principles of gyroscopic motion in detail
  • Investigate alternative theories to General Relativity and their critiques
Physicists, aerospace engineers, students of theoretical physics, and anyone interested in the experimental validation of General Relativity and the nature of gravity.
marcus
Dearly Missed
http://einstein.stanford.edu/
this is the website for "GravityProbe B" the test of General Relativity
using orbiting gyroscopes
someone told me that GP-B is already flying but
at this site it says that shipment to Vandenburg
for launch is scheduled for June 26, 2003.
Does anyone know of this planned test of relativity?
Does anyone know if launch has occurred or if not (as
I suppose) when it is likely to take place.
The spacecraft seems to be finished---have seen photos.
It carries four hi-tech (cryogenic?) gyroscopes and
extremely precise sensors to detect any tilt of axis
due to framedragging or whatever.
Can anyone explain this planned test of relativity
in layman's terms. Leonard Schiff, who thought it up,
first proposed it back in the Seventies. But it is technically
very challenging and has taken something like 30 years
to prepare. Apparently it tests some aspect of GR which
has not been tested and is capable of distinguishing between
Einsteins version of gravity and some possible alternative
models
Astronomy news on Phys.org
As you probably know, Einstein's theory of general relativity proposes that gravity is not so much the force as a geometric shape of space itself. You have probably seen the demonstrations of a bowling ball, or some heavy sphere, rolling across the surface of the trampoline. This is a fairly good intuitive picture of what Einstein proposed was happening to space that is occupied by an object with mass.
However, Einstein's model would be even better illustrated by showing a ball rolling across a pool of mercury. That is, GR pictures space as more fluid. Set a massive object upon it, and it curves. If that object is spinning, the space immediately around the object spinns with it. Gravity Probe-B will see if space itself is slowly rotating around our planet, being "dragged" by the spin of the earth.
Hope this is not considered "thread hijacking"! ;) But, it doesn't seem like the thread is going anywhere ...
This is about my most favorite rant .. Mach's Principle. I hate it, and don't believe it -- That the cause of inertia is the combined gravitational attraction of all objects in the observable Universe (given that the speed of gravitation is the speed of light).
Another manisfistation of Mach's Principle is what we are to believe that when we are spinning around-and-around. That smaks of absolute motion, i.e., we don't need to observe any other object in the Universe (or Relativity) to discern that it is us making the motion, and not the Universe. Mach's Principle would have us to believe it is just as proper to say the Universe is spinning around us, and we are motionless. Blllleeeeeeeeeewww!
Anyway, the tie into this thread -- I propose GP-C. I doubt it is technologically feasible, but take the gyroscopes outside the solar system somewhere where it is not so much influenced by local gravitational fields. Take two of them, in different directions. If Mach's Principle is true, shouldn't both of the gyroscopes align themselves with the distribution of matter in the Universe? Shouldn't they precess to the same direction, statistically a direction different to what we (Earth) are flowing through the CMBR, if Mach's Principle is true (i.e., the distribution of matter in the Universe is not as even as the CMBR).
Another rant against Mach's Principle. This may seem "duh", but think about it for awhile. Why are centrifugal forces manisfested only in 2 dimensions, not 3? We are to believe it is the distribution of matter in the Universe that let's us know we ourself are spinning, yet that distribution makes a difference only in 2 dimensions. You might say, "duh, you are only spinning in 2 dimensions", but spinning in 2 dimensions precludes you from spinning in 3 dimensions (neglecting precession). That 3rd dimension, and the distribution of matter in that 3rd dimension only seems to matter when you are spinning on an axis parallel to that dimension. So, how is the distribution of matter in the Universe causing me to know I'm spinning, when 1 spatial dimension is not being considered?
