Radius of convergence of an infinite summation
The discussion revolves around finding the radius of convergence for a specific infinite series involving a power series with a term raised to '2k'. Participants are exploring the implications of this term on the application of convergence tests.
  • The original poster attempts to apply the formula for the radius of convergence but is uncertain about how to handle the '2k' in the series. Some participants suggest using the ratio test, noting that it may simplify the problem. Others express concerns about their familiarity with convergence tests beyond power series.
Participants are actively discussing the application of convergence tests, particularly the ratio test, and how it relates to the original series. There is a recognition of the limitations in the original poster's understanding of general infinite series, with some guidance offered regarding the relationship to geometric series.
There is mention of the original poster's background in power series and a lack of exposure to general infinite series tests, which may affect their confidence in tackling the problem. The discussion also touches on the broader context of convergence tests and their foundations.
jacobrhcp
[SOLVED] radius of convergence of an infinite summation
find the radius of convergence of the series:
[tex]\sum\frac{(-1)^k}{k^2 3^k}(z-\frac{1}{2})^{2k}[/tex]
the radius of convergence of a power series is given by [tex]\rho=\frac{1}{limsup |c_k|^{1/k}}[/tex]
and is equal to [tex]\frac{1}{R}[/tex] when [tex]Lim_{n->\infty} \frac{|c_{k+1}|}{|c_k|}= R[/tex]
the major thing I'm stuck on is the '2k' in the series. General power series only have a factor 'k' in their powers, and I don't know how to get rid of it, so I can use the formula for radius of convergence of power series.
Well, actually if you did the ratio test you'll notice that 2k (both numerator and denominator_ will cancel itself out.
you're quite right.
I am not used to the tests of general infinite series, because we did power series before we handeled general infinite series and it's tests (such as the ratio test), which I'm afraid we won't ever cover. =( I'll have to study them by myself.
Thanks.
Remember the following, jacob:
We have basically, only one tool to determine whether a series converges or not:
Its "relation" to a geometric series!
Practically all of the so-called tests work because in the proof of them, we are able to tweak the condition into a comparison with a relevant geometric series.
how is that true? I mean, there are other infinite summations than the geometric series for which we know the radius of convergence, right?
Sure, there are!
But just about every test we have shows, in the proof of it, that if the test criterion holds, then our actual series will have some unspecified limit below that of a convergent geometric series.
